- Jul 27, 2003
Not sure what your question is, Nick.
Each successive plunge was slightly deeper than the one preceding it, until full depth is attained.
Then work backwards to eliminate the stair-steps.
We're just clearing a center path to begin stock removal of the width.
Most of the people on this forum either do not even own a mill, or might have a bench top mill.
This makes it easy on the tooling and the equipment and minimizes breakage to almost zero, which is a challenge in lower grade equipment.
If you are "...curious what the reason behind it is." I will say that it's because it works and saves time and results in a slot that FITS virtually every time with little deviation.
Take it for what it's worth, or don't take it at all, but I will repeat that Jerry Rados taught me this and Jerry had forgot more about knife making than most people I know will ever learn.
And he taught me on a Bridgeport. With a DRO. But he still did the stair-step and used a dial indicator.
That method eliminates just about everything that can go wrong.
It's stupid simple.
And I do really good with stupid simple.
It's stupid simple.
I'm not talking about cutting full depth in one pass. He made his cuts by plunge cutting a little and traveling in the X-axis a little, and then did that progressively across the slot. I've never seen it done that way, so I'm curious what the reason behind it is.![]()
