it looks like its time for a show down!
really the tri-ad is very strong and even more durable. Much more so than all of Cold Steels other offerings, which were very good also. I made overbuild frames locks for a long time and none come close to my new folders.
I was at Cold Steel a while back and LT showed me a giant box with tested folders (not CS folders). I dug through the box and was blown away by the tags on the folders. Many of our favorite folders marked "failed impact tests" or "held 60lbs".
Great idea!
The 2010 Knife Olympics, ... we have no champion YET.
Some guy named Sal has gone into hiding.![]()
Yup, Spydies are are OK :thumbup:, no bashing here at all. Just a little friendly competition would be nice to see though.
Actually the negative force is transfered to the backlock which happens to butt against the stop pin on the opposite the blade does. that is where the Triad gets it's tremendous strength. The combination of backlock and stop pin keeping the blade from closing. Scroll to the bottom of the page for a diagram.
http://www.coldsteel.com/triadlock1.html
At what point is the exceptional strength of the "best" lock so far beyond need, that even lesser lock are still beyond need? The rest of the knife would fail, the blade would snap, your grip would shift, before a Strider framelock would give way.
A
I also don't care who makes the lock. I have said nothing bad about the Triad lock. Who makes it has nothing to do with how strong it is. Saying that the only reason the Triad lock is being challenged is because of who makes it is, well, childish especially when nothing bad has been said about it. The only thing that I have read that is challenging anything, is the claim that nothing out there will touch the Triad lock in terms of strength that is based on the viewing of some you tube videos.
Except in my past 30+ years of using a lot of different knives (Hundreds) I haven't seen anything yet that is stronger in folders.
And it's durable even under hard use (Abuse) as in it won't loosen up or fall apart like some others have over the years.
I won't point fingers though at any makers.
here is an explanation of the Spyderco rating system
http://www.spyderco.com/forums/showpost.php?p=77904&postcount=11
I think this means it takes at least 750 pounds one inch from the pivot to break the Chinook (3.75" blade, 200 lb/in rating for MBC/extra heavy duty) I do not know how much it actually takes, just that this is the minimum to achieve the rating.
Well I think the oldest lock I am taking into consideration is the AXIS lock and it is 9 years old? All the others are newer.
Just curious but have you abused an AXIS, compression, or ball bearing lock? Have you abused a Triad lock?
Naturally, it would require a minimum 187.5 lbs 4 inches from the pivot for the Chinook to have an MBC rating.All that means is that once you get farther away from the pivot than one inch the force (Leverage) is increased.
If one is breaking at say 750 Ibs one inch from the pivot it would take less weight (Pressure) to break it the farther away from the pivot you get because of the increased leverage on the lock.
One complaint I have is that if they are so confident with the tri-ad lock then why is the warranty still only 1 year on their folders?
In Andrew's XL Espada video, he stops at 658 lbs 4 inches from the pivot - 2632 lbs/inch, and it hadn't broken yet. And the large Espada held 300 lbs 4.5" from the pivot for 95 hours - 1350 lbs/in (in-lbs?).
I'm good with the 1 year, it keeps the original cost of the knives down.
