HT Techniques and Procedures
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
Recent threads have brought a flurry of emails to my box. Most want me to post on these threads about procedures the OP and others use. I have no real desire to get into a "My procedures vs His procedures" discussion on these threads. However, I will yield to the requests for some explanation as to why I feel some of these procedures are not sound, metallurgically.
Please do not make this about personalities, or become a war,..... and keep replies to the subject of how things can be proven or disproven, improved, damaged, or unchanged.
STATEMENT ONE:
Any knife that you make that will stand up to the use it was designed for is a good knife. The methods on how it got hardened can vary greatly, but the metallurgy of what happens in the steel's structures as it heats up and cools down are fixed in physics, and aren't able to be changed by any chicken fat quench or special forging and HT technique.
In the same way, a knife that will do things that the intended use is not expected to do is not a better knife. There is a good reason that a fillet knife is a lot different from an axe. One is intended to cut meat cleanly and for a long time between sharpening. The other is made to take huge chunks out of trees, and be re-sharpened often. A fillet knife isn't a bad knife because it won't fell trees anymore than an axe isn't a bad axe because it won't slice tomatoes.
STATEMENT TWO:
Doing something that does nothing will not affect a blades final outcome at all. It is not proof that the process is superior when the outcome is the same as if you didn't do it. That is why you can't say that the chicken fat quench hurt or improved the blade...it was just the quenchant. If the blade properly hardened, it is a good blade. If the fat was a fast enough quenchant for the steel, it was OK. If a commercial quenchant is equally fast, there may be little difference on a single quench. However, if you do 100 quenches over a year, the commercial quenchant will defeat the chicken fat easily ( unless you render down 100 new chickens ever day). Stating that the chicken fat made a good blade is just defending your procedure, but does not making it superior.
STATEMET THREE:
Lets just go straight to the biggest contention about HT processes - Putting the blade in the home freezer overnight.
I will make an analogy - John and Jim both take a trip to Washington DC to see the Capitol. The trip is 200 miles. John drives 50 miles, spend the night at a motel, turns around the next morning, and comes home. Jim drives for four hours through traffic and gets to DC, he spends a few hours there and comes home. Which one saw the Capitol? Right, Jim. No matter what John says about his trip, he never made it to DC. He can tell you how much fun he had in the pool, how good his meal was, etc....but he can't say he saw the capitol!
When you quench a blade the steel structure changes from austenite at around 1500F to martensite at around 400F. This continues until the steel finishes the transition. For carbon steels, the finish line is usually around 200F. By the time it reaches room temp, the race is over. In complex steels with higher alloy ingredients, like stainless steel, the finish isn't until around -100F. A home freezer reaches about 0F, this is the same as John's trip. Going partway is just as good as not going at all. It won't make the steel a little harder by getting it a little colder. Also, the transformation happens literally at the sped of light. Overnight won't do anything that ten minutes does ( which in this case, is nothing). Overnight ten times won't equal -100F, either.
The thing that gets missed in most of these discussions is that if the steel is a carbon steel .... the steel was already converted to martensite at room temp. 0F isn't going to convert it anymore than 70F. If the blade has already been tempered before the freezer, what possible changes can be attained, as the martensite will be well stabilized by then, and RA will already have been converted. The freezer would have no more effect than putting the blade in a closet overnight.
STATEMENT FOUR:
The transformations of steel structures are well understood and not "still being discovered". The changes that can be made are governed by metallurgical science, and they can be used to get a desired result in a blade. However, adding steps that do nothing will not make the blade better. If the grain has been properly refined in preparation for hardening, one quench hardens the blade. Two more, or a hundred more, won't make it harder or appreciably finer grained. If the results are good, it was because the LAST quench was good, and the blade was properly prepared for that quench. Every time you re-heat the blade, the slate gets wiped clean. It does not remember every thermal event that ever happened to it. It only remembers where it was when you started to heat it up from room temp. Next time it will only remember where it is now.
Think about it, If the steel was permanently damaged by having a large grain structure, and it could never forget that, how could you make the grain smaller? How could you forge it? Now, I will admit that there are some things that can be made much more permanent in steel structures and things like carbides, but these things aren't what we are changing in normal HT procedures of carbon steel blades. Thermal cycling followed by a dead on quench in the proper quenchant is the key to a properly hardened blade. What you change from there as far as making some parts softer is up to you, but you can't improve on the final outcome by repeating the quench over and over.
STATEMENT FIVE
Anyone can say anything and someone will believe him/her. That is what a following is. Some may call him/her a dreamer, others a free thinker, some a fool....but if the claims can't be proven, they are only that persons ideas/words. If someone has a metallurgical reason that a new procedure does something, they can explain how their process works. In basic knife making this is pretty simple to do. It is just as simple to disprove a statement as not being sound. I don't have to test someone's knife to say that 0F is not -100F. If he is claiming that something happens at 0F that metallurgical engineers have never seen, I ask him to show the evidence of that. If the only evidence is that the knife is a good knife, refer to Statement Two.
FINAL COMMENTS
All the above doesn't make one persons knife a blade a good blade and another's a bad blade. What makes a good blade is a good HT, proper steel selection for the task, proper blade geometry for the task, and good procedures for the shaping and HT. Some do this with the most rudimentary of tools, and others with high-tech equipment. Again, one or the other does automatically make a blade good or bad. Learn HT by learning what happens and why it does. Then you can develop your HT procedures to fit your situation. In the final result, a good knife is a good knife.
"But Stacy, I saw the Capitol...in the postcard they had in the lobby of my hotel!" - John.
Thanks for the explanations. Very well thought out post.
Nicely done Stacy
Extraordinary claims require extraordinary evidence
Thanks Stacy..A nice post and clears up a lot of my questions regarding this subject. I think it is a clear by what you are saying that a lot of procedure's that some do are just not worth the time and effort based on the fact that there is no proof that anything beneficial come's of it. I think for me my time is valuable and I don't want to be running a fool's errand this extra time can be put into the final finishing aspect of knifemaking.
Thanks again
Don't even TRY to deny it, Stacy. You have been reading a "Leading Knife Magazine" again. You know very well that it only serves to make you angry. I have said this many times before but it is always worth repeating: you can't stamp out dumb. I might also add that it is no one's duty to save all the fools from the clutches of charlatans. We have probably all been fooled by a charlatan or two or three in our lives. I know that I have been. I was fooled by the books of two very well known charlatans. But I figured it out by my self that I had been lead astray and I redirected my path. I honestly believe that I am the better for it. Those innocents who follow charlatans are not innocent at all; they have just not worked hard enough yet. Your intent is noble, Stacy, but it is in vain. Read your own words, Stacy. Of course what you say is true. How could it NOT be true? But how do any of us get to the truth? We have to work for it. We have to WANT to get to the truth. We have to try and fail and try again. We ALL want "15 Easy Steps To Enlightenment" but we ALL know in our heart of hearts that there are a lot more than 15 steps to any journey that is worth our work and failure. The steps we take down false paths that cause us frustration and pain are the price we all pay to find our way. You are truly a good and noble man, Stacy, but the innocents will find their own way if their intent is as noble as your own. And don't worry; they will not even loose their innocence or their sense of wonderment in their meandering. They will only have tried and failed and tried again. They will have labored hard at a job worth doing. They will have paid the just dues to follow a path worth following.
Metallurgy is a science. Period. I am not a fan of all the mystification of h.t. procedures either, and I appreciate someone whose opinion is held in high regard in this community clearing this up.
so how do you explain the one to 1 1/2 point hardness increase on 52100 observed during Jominy testing in the lab at koppel steel from an overnight stay in a freezer at -15 degrees F. Also why where there patents issued in the sixtys for multiple quench procedures if nothing was being accomplished? Why will blades quenched in an oil that has a faster quench speed than specified for a certain steel break much easier than those quenched in an oil that is as specified for that same steel? Both oils made the steel hardnthey where tempered to the same final hardness. Are you impling that modern metalurgical seince knows everything there is to know about steel? Do you have a masters degree or above in metalurgy?
Excellent post Stacy! So far I have been working exclusively with 1084 and have been itching to build a propane brick forge to try my own heat treating. My original thoughts were fairly clear as to the process. Heat to the right temperature, quench, then temper. Not all that complicated. Lately though, some posts had me thinking the process may be more complicated than my experience level could handle and left me a little too intiminated to give it a try. I think you just built up my confidence a little and I once again feel I could handle it. Thanks!
Patents do not have to be proven as useful, just that you are the first to do that.
You can read all the patents at the US Govt site, very few have value.
I think for me my time is valuable and I don't want to be running a fool's errand this extra time can be put into the final finishing aspect of knifemaking. [/QUOTE said:
Completely agree!! Time could be better spent. More knives could be made in that time!
One of the analogies that have been used for teaching the process of becoming an expert goes like this: A man is climbing a mountain. He makes numerous judgements as he continues to climb his way to the summit, with many false starts, and near misses. Once he reaches the summit, he looks back and sees the path to the top as a single easy to follow trajectory, since he now knows what lied at the end of each false turn. Makes sense to me.
Bill, I didn't say that a triple quench does nothing....just that it doesn't do anything thermal cycling of the steel in preparation of a single quench does.
As to the Jominy test as a guide to knives, that is apples to oranges. The Jominy ( AKA End Quench Test) test is to determine hardenability, not hardness. It is displayed as a chart that shows how deeply a steel hardens in a particular quenchant by inserting a 1" round bar of the test steel into the quenchant. The hardness measured at different depths determines the "hardenability" or depth of hardening of that steel. Triple quenching a 1" bar drives the hardened steel deeper every quench. The outside gets harder each time, which is no surprise. In a knife blade thickness, through hardenability is reached in one quench. There is no soft core to try and reach like a 1" round bar has. A knife properly austenitized and quenched in the correct quenchant will be equal, ( maybe higher), than the Jominy hardness chart shows as the surface hardness for a triple quench. The triple quench in knife making is not the same thing as that test, though.
Why will a blade quenched in a too fast quenchant break easier than one quenched in the right quenchant ??????
Because it is the WRONG QUENCHANT.
No, I don't have a masters degree or above in metallurgy, however, I don't see what that has to do with the discussion. Third sentence in this post"
"Please do not make this about personalities, or become a war,..... and keep replies to the subject of how things can be proven or disproven, improved, damaged, or unchanged."
I don't understand why freezing would be a part of Jominy testing, then? Just trying to get the most out of lab time?
Very good answers to the questions Stacy. I was curious as to what replies might be made. You covered it very well. Conclusions made from of a grouping of facts are not always valid, when there are still some that are absent by neglect, wishful thinking, or purposely.
The right quenchant yields right cooling rate (for particular steel & aust temp) - correct? Can this right quenchant provides an uniform volume cooling for a ffg steep distal taper blade? Shades of grey :confused:
Bluntcut are you referring to hardening the entire blade or the cutting edge. I think (if I am not mistaken) that you are still referring to a thickness of under a quarter inch right. When we are hardening blades the cross section is very small. That is the reason that you can get away with using a fast oil and still get reasonable hardenability vs using water or brine which may be the recommended quenchent for items that are thicker of the same steel. This is for carbon steel and associated alloys which is the only thing I know anything about.
