...How many times have you gone to a for sale forum and seen, Terzuola, Carson, Emerson, Lum, Lightfoot and Fisk...only to see they are factory versions. This is of course exactly what the factories wanted.
WWG
You have posted this same example, over and over on these forums. Again, "custom" makers have profited well from their interaction with the "factories". While it does not make custom knives obsolete (original thread subject), it does bring the products closer together.
... Gerber Dagger...
...Randall Mdl 14 ...
...Cold Steel Tanto...
...Gerber BMF ...
... Buck 110 ...
...Schrade folder... ... Gerber boot knife...
WWG, climbing off of his high horse now.
WWG
Except for maybe the Randall (which is still current) - you are 20 years behind the curve. Presumably (except for the Seki Lum, none are listed) K8 is NOT referring to any of these as examples of productions pushing up on customs in terms of performance. I know I am not. It is of no value to pick the cheapest factory knives and compare them against some of the most expensive custom utility knives.
I have chipped the edges of a Phil Boguszewski Mini Cobra (BG-42) when chipping ice. Phil was very surprised about this when I called him. I have bent the edge of a Tom Mayo TNT blade on a similar task. I wasn't cutting, I was chipping and prying, which of course these things aren't designed for.
If you are going to argue the "custom" side of this topic, at least know what you are dealing with - try a Spyderco Lil' Temperance, Spyderco Street Beat, Spyderco Chinook, Benchmade Osborne 940, Chris Reeve Mark VI, etc. I think you will find that any of these perform very, very well against any knife.
Now Architect, it is time for you to chastise K8 for his lack of examples.
K8, you are still full of S**T. Architect I expect to see a "High Horse" comment from you with regards to K8's opening statement
WWG
I agree that K8 has not done much to advance the original idea in the further postings. I tried to elevate the discussion along the collaboration issue, but no takers except perhaps Scott Dog. Since I use my knives around my property, I try use the right tool for the job, so I rarely have to improvise with my knives. When I am camping, I have ended up doing some prying with my knives, but not too often. Since I carry both factory and custom knives, I can say at least on my end, the difference comes ( and particularly so in folders) on blade grind geometry and pivot build as much as anything else. For real outdoor use, of most importance to me is the simplicity and reliablity of the locking mechanism. How will it hold up when subjected to poking around in dirt? I had my Sawby Combat Utility knife on me while I was planting a large tree. When cutting off the plastic tub and root ball fabric (which it did very well, and those plastic tubs are very thick on a large tree), dirt got lodged into the seating area of the tang. I literally could not close the knife and get the lock to set. I called Scott in the afternoon. Turns out I needed a needed to get the fine dirt out of the grooves on either side of the seat. Even a custom can fail under the right conditions.
