- Apr 12, 2009
Too thin and flat bevel can create nasty stiction (food/material stick to blade). Hollow grind helps. Thin but with some convex cutting bevel also lessen stiction. Depend on target cutting material, key is to get the right amt of wedge to stretch material then the apex has an easier job fracture 'stretched' material, and then continue wedge material away from stick to the blade. See ... hahaha, this tastes best when add a pinch of combinatorial optimization.
I agree with that. I've noticed that apples have a nasty tendency to tightly grip a flat grind or even a thin convex used in halving or quartering them. They're the only thing my Opinel (thin convex grind) won't slice too well, as the blade gets wedged in mid-cut. I've come to prefer a very thin hollow grind for those, as the hollow in the grind seems to relieve that stiction pretty well; the thin & full-height hollow of a Case Sod Buster is perfect for apples. Also noticed the same tendency with watermelons, which feel very much like a vise if trying to use something like a wide & flat chef's knife to halve or quarter them. A narrow (spine-to-edge) and thin, flexible hollow- or sabre-ground blade, such as found in a long fillet blade, handles those much better.
David
