- Mar 7, 2001
Big Chris,
Thank you. You mean the Z wear was zero ground (what is the initial angle?) and tested by adding 24 inclusive bevel bit by bit until it is stable?
Working out calculation, 0.006" - 0.008" is about 0.15mm - 0.2mm, which is 150-200 micron. Some stats I read has carbides size varies around 5 - 20 micron, depending on steel & heat treat. With 30 inclusive (easier to calculate), it works out about 350 micron edge height (if thickness is 200 micron). Within this 200 micron base with 350 micron tall, the matrix surrounding 5 - 20 micron carbides that's not too dense should suffice to hold them stable.
I have to re-look data to check how much carbide in volume just to satisfy my curiosity.
Come to think about it, most production knives are way too thick!
