- Sep 8, 2014
Meant to ask a bit ago.. American Chestnut should be good enough to use without stabilizing, right? We've got an old semi dead one on the mountain I wouldn't mind having a chunk of either.
M4carbine.net is another good site. When I put mine together I bought a stripped lower and parts kit and bought an assembled lower to simplify things, but I don't have access to the tools and everything that you do.
It really depends on what you're looking for. If you want just a plinker to have fun with than del-ton, Palmetto state, DPMS or just about anybody is fine and should work. If you want something more serious than you want to look to Bravo Company, Lewis Machine & Tool, and the high-end stuff like that is where you want to look. For durability and reliability's sake make sure to get a top quality bolt and bolt carrier that has a properly staked gas key. M4 feed ramps on the barrel extension are a good thing to have too.
Another thing you may want to know is that a chrome-lined bore and chamber used to be considered a must-have but it is being phased out in favor of other processes (unfortunately I don't remember what they're called) that do the same thing but better and for less money as well as being more precise. At the very least get a chrome-lined bore and chamber if you don't feel like researching everything since those should still be all over the place.
I think hoss meant an assembled upper, not lower. The upper is the only part that really requires specialized tools (barrel wrench among others). There are some tools that make putting the lower together easier, but they are not absolutely necessary.
Nitrided is one of the treatments that is now in vogue. ...and is supposed to be incredibly hard.
Just research it online, theres all kinds of places that will stabilize wood for you. CF suggestion of K&G is a good one. As far as doing it yourself, well, yeah you can do that, I have, but it will never turn out as good as what the pros will turn out. By the time I made a pressure vessel and vacuum pump, hoses, hardeners and such, put it all together and experimented with it, I could of taken that money and had it professionally done with better results.
.........In other news, finally got the go ahead from the wife to build a AR. I decided that I am going to machine my own lower. Any of you AR guys have any advice, suggestions, info, tips, resources on uppers or builds in general?
Thanks for all the AR info guys, I went through all the responses and thought it would take to long to address everyone so I'll just spill it all out here.......
First of all what kind of AR am I after. I want something dependable, and accurate..... As simple as that. What caliber? I like the .223/5.56 and the 7.62X39MM.....
I dunno if that's the only reason. If you want to build something truly premium with custom parts, you'd go the builder route also. Say, if you want a premium barrel, like Krieger, or Lothar Walther, or Criterion, or a tier down, such as Rainier Ultramatch. Then there's Ballistic Advantage or Aero Precision, or a variety of others. A Colt AR shouldn't cost you 1000 either. I've seen them go for 700 if you pay attention to deals, and you can build a decent battle rifle from parts for under 500 if you pay attention to sales, even with Magpul furniture. Not too shabby. 1000 could get you an upgraded trigger, barrel, BCG, selector, mag release, and buffer in a budget build right now. Or a standard build and at least a thousand rounds of ammo for it.
See, this is when I'm totally out of my element when it comes to manly stuff; I've never owned a gun 90% of my total shooting experience has been at indoor ranges.
Might start a custom gun shop down the road.
Chrome lined barrels. Its my understanding that the chrome was added to the inside of barrels to achieve tighter tolerances. Make it slightly oversized and sneak up on the finished tolerance by adding the chrome. They are getting away from that technique simply because rifling techniques,have improved so much just in the last 20-years that that chrome is obsolete. The Nitride coatings are the go to thing, and as a person that has spent all of his adult life working in machining and fabrication. Believe me, Nitride is some wicked shit!
I'm curious to know what goes into the pie to give it authority?
gunpowder & cast iron shavings?
For AR15's I say stick with 5.56. I'm sure you're more than capable of building an AK from a receiver flat which would also be considered an 80% receiver if you really want to shoot 7.62x39. The magwell of the AR15 and the extreme taper of the 'x39 cartridge usually work alright but you can't beat an AK mag for feeding AK ammo.
Oh goodness, if you start working on guns I'll have to start direct depositing my pay into your account.
I believe the chrome lining was mainly for corrosion resistance and durability and one of the major downsides is that it's difficult to control the thickness and accuracy can suffer. As I understand it, the army's M-110 (variant of an AR10) sniper rifle lacks a chrome lined bore and chamber for this reason
Agree 100% a grand is steep. Not to mention, Ruger is selling there new AR 5.56- brand new in the box cor $600. and I hadn't seen a bad review on the gun yet.
See I can also and will make some things that most people wont or cant, I will machine the forearm, I will make my own grip and stock as well. I have a lower casting I got for $30. billet aluminium. I will buy a barrel but make everything I can here in house. Put my T.M.Hunt stink on it!![]()
You guys are killing me with the AR talk. I am saving up for one this winter. I have thought about building my own but I am not sure. I do want a Windham Weaponry AR-15 since they made right here in Maine.
As always advice is welcome.
Jeremy
