Yep! I bet the outer sleeve is missing from the blade stop pin. That's what it looks like is causing the blade play to me anyway. I smell a troll!What name were you here under back in 99 ? You have only been a member here since 2012 with your "sothernknives" account ?
Is there any particular reason you don't show the stop pin in your video ? I presume it's because you removed the sleeve to get the play you were looking for ? It is just not possible to get that sort of play from just a worn lock face, there is simply not that much room. Removing or doctoring the stop pin sleeve would do that though, you even admit to replacing it your self. I can't wait to hear what Chris has to say when you send it in.....
Edit: Anybody that is inclined to check will notice that removing the stop pin sleeve produces the exact results we see in the video. This is a pretty clear and obvious troll attempt. Don't get sucked in here guys.![]()
The one thing I noticed in the vid is it seems that the blade is off center, which to me says the possibility of washer misplacement. Something is way off on this knife. Not normal even if it does have lock rock which doesn't happen on the 21. Normally.
That kind of issue doesn't happen overnight/gradually. There had to be a particular incident that caused it. Looks like you have a major impact indention on the end of the lockbar. Can see it at 3.00 minutes - 3.05m in the video.
Then why are you calling what you show in the video lock rock when it's clearly up-and-down blade play?Now I've got a tripton telling me he doesn't think I know what rock lock is.
I've been on bladeforums since 98' member since 99' and I knew what lock rock was before then.
Exactly, this video was made for moxy. Who didn't believe there could be any rock lock on a sebenza.
In closing arguments I must say, you can not refute any of my statements and be correct. Last post in this thread![]()
The stop pin sleeve's in. Not cure what could have caused the problem, but that's not it.
http://www.youtube.com/watch?v=B4nwXOkhiOU
Then why are you calling what you show in the video lock rock when it's clearly up-and-down blade play?![]()
Enlighten me...please.
I see no one responded to this. There is a difference between lock rock and blade roll.
Lock rock is the actual spring moving/slipping/walking to the unlock position.
Here is an extract from my longer framelocks posts.
"Three points of contact:
1. Stop pin
2. Pivot pin
3. Interface between blade and spring (ie, lockface/lock engagement area hereafter referred to LF) Spring is also the liner lock, framelock.
This forms a triangle.
Now, the LF is the area lets focus on first.
BT. refers to the angle of the lock face to be between 7.5 and 8.5 degrees. Les then 5 degrees and the spring will jam. More then 10 degrees and the spring will start slipping off the LF.
Now the start of a radius lock face, the maximum therefore cannot exceed 10 degrees or else the lock will start slipping when the lock wears to that point. As mentioned as lock rock in the video when referring to the Strider (http://www.youtube.com/watch?v=VUoVPLirWg8)
Now.
Do not think the angle plays the only role in the lock slipping. The finished LF can have a rough spot, not be polished enough, the spring's interface between the LF can also play a role.
Let us examine this from the Emerson website.
http://emersonknives.com/blog/emerson-knife-anatomy/
If the LF connected to the spring more in the middle or at the top of the spring where the detent is on most (point nr 3 closer to the pivot pin nr 2) then you would experience blade roll. This is when you have vertical type play but what happens is the blade actually rolls on the spring because the spring connects in the wrong place with the LF."
If we look at your video. We can see that at the 3:15 mark the spring is not even engaging the blade. So there is no contact on the LF at any point as illustrated. The spring/titanium handle needs to be replaced. It is worn out from use. Wear and tear. It will have to go back to CRK IMO to have the problem fixed.
This is what happens when people decide to make youtube vids and post on forums, instead of contacting the manufacturer or reseller in the first place, as they should always do.
It leaves everyone reading to speculate. With poor explanation in the video and 0% information given in the thread, it does CRK a disservice, IMHO.
