Bench rest gets used a lot for varmint popping.
Enough of the analogies, skills don't get passed because they aren't needed. Freehand is a PITA for a lot of people.
And Skimo, you're right. Today, most folks can't make their own furniture, or grow their own food. Why? Because there is no need for those skills today.
Are you implying freehand is no longer needed because of gadgets like the EdgePro?!
That's crazy talk, I almost spewed my coffee(made with a French press, not a Keurig). By that reasoning, there's no need to sharpen anything, a steady supply of (poorly) sharpened, brand new knives awaits one no further that the nearest supermarket.
I must strongly disagree on all points.
Yes, I certainly can sharpen a knife free hand. But it will not meet my standards. Free hand does not allow the control necessary.
The Edge-Pro gives far superior "feedback" from the stone to anything I ever experienced free hand.
With an angle cube to set the stone arm, I have absolute, precise control of the angles. I also have far better pressure control with the stone arm than I ever did free hand. I can tell easily if my pressure is correct just by the sound of the stone on the steel.
To say that a person has never sharpened a knife if he hasn't done so free hand is pure hogwash. I've never had to repair a blade that was damaged by a new sharpener with a guided device. (Specifically exempting powered devices) I have repaired numerous knives that were severely botched by new people free handing.
If you enjoy free handing, then more power to you. Keep using that method. But please do not denigrate those of us who appreciate technology.
You've gotten a lot of good advice here, but I have a little bit to add.
You want to start simple so you don't confuse multiple systems or techniques. The few knives you mention have steel that's much more difficult to sharpen than average steel. Check to see what your practice knives are made of. Cheap stainless would be fine. 8Cr13Mov, Sandvic steel, AUS8, "440C", or any regular stainless steel would be fine. No super steels!
Start with one fairly coarse stone. That could be your King 1000 grit. Or a hardware store Norton stone (Silicon Carbine AKA India). Or a coarse diamond stone if you decide to buy those. Just make sure you have a coarse stone. You need one more item: A black, red, or green sharpie.
Ok, practice knife you don't care about. Coarse stone. Sharpie. Color the edge of the blade with the sharpie and use that to see where you are hitting the edge. Grind a few strokes, then look to see where the sharpie has been scratched off. If you don't know what part of the knife you are grinding, you probably won't make good progress. The sharpie will show you exactly where you are grinding. Reapply it often and keep observing where you are grinding.
Do you know how to check for a burr? That's huge. Forming a burr should be your #1 goal, with edge angle control being #2. Stick with that one stone, one knife, and sharpie until you form a burr on the entire length of the edge. Then do it again on the other side of the blade. Then remove the burr with lighter strokes. At this point, the knife should be relatively sharp. With a King 1000 or a DMT Coarse, it should shave at this point *if* the burr has been formed and removed.
The keys here I'm trying to emphasize: Coarse stone. Burr formation. One technique. Repetition.
This is longer than I intended, but I hope it helped.
Good luck.
Brian.
How DO you check for a burr though? Can you just feel it with your fingernail? can you see it?
I have to disagree with you -G, if you haven't used an Edge Pro before, I suggest you go ahead and try it out, it's not an automatic razor sharp edge by any means.
You have to know how I sharpen, you have to adjust your angles, you have to control your pressure.
I wish I could just drop my knives on and magically have a shave or EDC ready edge, then I wouldn't have to take the time and effort to get what I want. I know better, and so should you.
That's a sad mindset. No wonder there aren't any skilled workers available; they're all a dying breed, men who didn't compromise because something was a pain in the a**.
Lastly, buy a coarse/fine DMT diamond hone and call it a day.
Factual. I was never able to free hand before I mastered the Edge-Pro. Once I did, I understood the basics of sharpening, and the little technicalities angles, and pressure of blade and stone. After that, I gave free hand a try once again, and was able to get some very good edges. My free hand skill set is most certainly not in the league of HH or Mag, but I can put a shaving edge on a blade without undue difficulty free hand. I could not have accomplished that ten years ago, regardless of effort expended.
I think the debate here is not really about sharpening a knife, as much as it is about developing an artistic skill vs using modern technology to achieve the best result with the least effort and time expended. Both points of view are certainly valid.
In the final analysis, the only objective is getting the edge you want and need on the blade. How you achieved that goal is really quite irrelevant.
Too bad this thread became retarded. There was some really useful info in the beginning.![]()
You never go full retard!!!
Hey Mods, Lock this purse fight down, would you?
