- Nov 27, 2021
Thank you
Congratulation for this job I appreciate your efforts trying to put some objective facts on this very traditionnal segment.Recently I was able to acquire a used CATRA machine, so I heat treated just about every knife steel I had, made 57 knives with the help of knifemaker Shawn Houston, and tested them all to see which cut the longest. For a few of the steels I did multiple heat treatments to look at a couple variables and to see the effect of hardness. I also compared edge retention and toughness to see which steels have the best balance of properties. https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
Kudos. Folks will reference that work for years.
I'd like to see something like that done with a large number of production knives from the industry leaders. Sort of like what Consumer Reports does, but better. The Forged In Fire tests are fun to watch but are only focused on two or three blades at a time, then changed for the next show.
I want a CPM 10V blade. Too bad they’re hard to come by…
Holy shit. That was incredibly information dense, articulate, and well done. Thanks man!Recently I was able to acquire a used CATRA machine, so I heat treated just about every knife steel I had, made 57 knives with the help of knifemaker Shawn Houston, and tested them all to see which cut the longest. For a few of the steels I did multiple heat treatments to look at a couple variables and to see the effect of hardness. I also compared edge retention and toughness to see which steels have the best balance of properties. https://knifesteelnerds.com/2020/05/01/testing-the-edge-retention-of-48-knife-steels/
Cobalt affects the formation of tempering carbides, not the vast majority of the carbide that affects wear resistance. If anything it increases the amount of those. When it comes to tempering carbides it affects the size and distribution not so much the amount.Hey Larrin, I saw where in your testing of S110v that it was a little less wear resistant than s90v and you couldn't understand why, I think the reason might be because the cobalt in it actually reduces the amount carbide formed in the blade by making formation time longer. I know alot seem to miss that fact because the first thing they think of is well why would high speed steels use colbalt in them if it reduced wear resistance, but thing is that cobalt is for increasing red hardness so it stays more wear resistant at high temperatures during operation, in a highspeed application s110v would indeed outperform s90v but outside of that application it actually has less total carbides formed and therefore less wear resistance at room temperature.
Larrin - as one late to the game (of your site) I have to tell you thanks so very much. I had a site bookmarked that for yearsss I referenced as for my steels. I basically just took a cursory glance at what I wanted to see on your site and knew I hit the motherload. Again - much thanks!Cobalt affects the formation of tempering carbides, not the vast majority of the carbide that affects wear resistance. If anything it increases the amount of those. When it comes to tempering carbides it affects the size and distribution not so much the amount.
