At same ticknes and heat treament S35VN has allmost two time better toughness than AEBL. 58Hrc is not best thing ever. Its optimal hardness for all blade steels.Optimal does'n mean best. It's crossroad. You can't have right results when you sharpen knife and when you cutting with same knife if you rase only one variable (hardness). CPM125V is everything but optimal steel. Magnacut can be.Depends on the steel and use of the blade. Magnacut is optimized at 61-64 HRC, with a balance of toughness and hardness. This would be for anything up to (roughly) a 6 inch hunting style knife. Anything designed for heavy chopping would, of course, be better optimized at a lower hardness, but that would not be where a high alloy steel shines.
Take AEBL for example (one of my favorite lower alloy steels). At high hardness it still support a thin edge (62-64 HRC) while remaining relatively tough (equal to 52100 bearing steel). In a larger blade, I would lower that to around 60 HRC as it would likely absorb more abuse. S90V I run at 61-62 as it was designed as a high performance cutting steel, not a tough chopping alloy.
Point being, general statements like "58 HRC is the best thing ever." are patently wrong for most steels and uses that a knife would/should be expected to perform.
Follow the science. Doc Larrin has done quite a bit of research and testing...I highly recommend the read (link at the front of this thread - post #1).
Give me 62 Hrc any steel and i will destroy it on bone, stone, other steel, wood. German meat cleaver cuts bone on 56Hrc better than knife on 56 Hrc. If you cut paper with knife or shave hair with knife that doesn't mean that is knife better than scissors or razor. This is real meaning " right tool for job", not different knife or steel.@zorandjurkic I find the strength increase in higher hardness in knives to be beneficial to a point. Give me Magnacut any day at 62 Rc vs 58. At 58 I will have edge roll with sloppy butchering bone contact but at 62 I do not. Big difference in my world.
Elmax on 58 Hrc is not best steel or best steel hardness, it's optimal. Edge holding is not edge quality. Longer edge holding means much harder sharpening, chiping of the blade and easy breaking of the blade. But, again, 58 Hrc is not best thing ever. It's optimal thing ever and only for knife blades. I don't know what is optimal hardness for ball bearings. You use AEBL and it's ok. S35VN is still twice better on toughness. And it's not because i say that.Your initial statement was that an Elmax knife at 58 HRC was the best. The numbers don't lie, and that is patently false. Elmax is optimized for use in the 62-64 HRC range. Below that you lose the benefits of that alloy and essentially have a easy to sharpen sub-par knife. This thread is about the comparison of steels in the category of edge retention not toughness. However, I would like to address the s35VN vs AEBL claim. Take AEBL vs S35VN at a hardness range between 60 to 62.5. AEBL demonstrates toughness ratings between 40 (at 60 HRC) down to 20 Foot/pounds. S35VN from 10 down to 7, less than half the toughness of the lower alloyed steel.
A 56-58 HRC steel in the same alloy, same geometry will absolutely NOT hold an edge longer than the same at a higher Rockwell. Properly tempered, A higher hardness steel will not be brittle. I have used and have had many pro-hunters use S90V at 62 HRC to skin out and process many game animals without major edge damage, that includes running the edge up against bone and carving seasoned wood. Can't speak to smashing it into stone or steel. The benefit to high hardness is more cuts before needing to be sharpened.
A skinning knife at 56 HRC just won't cut it (pun intended) and many of them report processing 2-3 times the number of animals as a commercially available skinner (unknown hardness, but assuming lower than 60 HRC based on what I know at least 3 of them used in the past).
I'm out. You are, as I said, set in your opinion, and I have knives to grind.
For an independent test check this out and see where Elmax scored at 58 HRC: https://www.bladeforums.com/threads...ed-on-edge-retention-cutting-5-8-rope.793481/
(bold added by me to highlight the statement)At same ticknes and heat treament S35VN has allmost two time better toughness than AEBL. 58Hrc is not best thing ever. Its optimal hardness for all blade steels.Optimal does'n mean best. It's crossroad. You can't have right results when you sharpen knife and when you cutting with same knife if you rase only one variable (hardness). CPM125V is everything but optimal steel. Magnacut can be.
Exactly! 58 Hrc is optimal hardness for all knife steels.(bold added by me to highlight the statement)
I'm not sure if you understand what optimal means.
Yes, I understand.(bold added by me to highlight the statement)
Bold claims require proof. Please show your references for your claim. Thank you in advance.At same ticknes and heat treament S35VN has allmost two time better toughness than AEBL.
Geometry has to be ruled out.Give me 62 Hrc any steel and i will destroy it on bone, stone, other steel, wood. German meat cleaver cuts bone on 56Hrc better than knife on 56 Hrc. If you cut paper with knife or shave hair with knife that doesn't mean that is knife better than scissors or razor. This is real meaning " right tool for job", not different knife or steel.
Before i do the test please look this video. It's not proof but take a look.Bold claims require proof. Please show your references for your claim. Thank you in advance.
I must admit that i don't understand.Geometry has to be ruled out.
How is ‘testing’ a previously broken knife even considered valid? Just curiousBefore i do the test please look this video. It's not proof but take a look.
You posted a lot recently. I must admit I got a bit lost. Can you resume what your point is in no more than a few sentences?I must admit that i don't understand.
I sead that isn't proof but all tre knives were broken on handle and he tests blades (they haven"t been broken). Maybe he tests two different steels. How should i know? It seems that doesn't lie or have any reason to. But he is not testing machine. So it isn't proof. If we test two blades (AEBL and S35VN) at 58Hrc we will know ( not at 57 or 59). Beside why we even do this? If you have knife with blade of 8 inch in combat its not bad but if you have knife of 20 inch blade that would be better. 20 inch knife is sword. That prooves that swords are actually knives.How is ‘testing’ a previously broken knife even considered valid? Just curious
Not if grappling! Lol.I sead that isn't proof but all tre knives were broken on handle and he tests blades (they haven"t been broken). Maybe he tests two different steels. How should i know? It seems that doesn't lie or have any reason to. But he is not testing machine. So it isn't proof. If we test two blades (AEBL and S35VN) at 58Hrc we will know ( not at 57 or 59). Beside why we even do this? If you have knife with blade of 8 inch in combat its not bad but if you have knife of 20 inch blade that would be better. 20 inch knife is sword. That prooves that swords are actually knives.![]()
It shows.I must admit that i don't understand.
It’s on sale right now:https://www.amazon.com/Knife-Engineering-Steel-Treating-Geometry/dp/B08D4P9D95I must admit that i don't understand.
That is the first edition. Second edition just released.It’s on sale right now:https://www.amazon.com/Knife-Engineering-Steel-Treating-Geometry/dp/B08D4P9D95
