You aren't alone.I like S30V and U2. Is that allowed?
Another issue with prioritizing geometry is that the end user can much more easily change the geometry of their knife than they can to heat treat. It is relatively straightforward thinning a knife or adjusting the bevel to make it cut better, however trying to reheat treat the blade would be significantly more challenging and out of the realm of most people's capability.You are right. I did not say that Geometry is the only factor making a good knife . I only wanted to say that Geometry for me is the leading factor. Of course when all contributing factors to a good knife for you come together it is always better!
When the steel is in such bad condition as you describe only the waste bin remains as the last resort..
By the way ( speaking about Victorinox) I give to anyone on a tight budget who is asking me what kitchen knives I would suggest the Victorinox FIBROX serie. A good example of cheap good stuff if you do your part in the geometry/ sharpening/stropping area. Even a much better suggestion for many people than a 400 dollar Japanese “ high quality , high hardness” steel knife.
Been interesting reading the results. Bob Dozier D2 proved heat treat make a difference. I have experienced D2 out of China vs EU Manly at 60ish whom had probably the best value knives till they stopped. I'd say better value than even Chinese whom stop at 58hrc with their native D2. Points snap and chipping is the thing here. Geometry.
10Cr15CoMov often sold as VG10 and all sorts of others has some ductility. I made a hollow internal tang but due to surprising flex at 60 used the solid tang instead. Has D2 beating edge retention in my layman hunting experience and sisal rope. At least better than vs Chinese D2 at 58.
Had possession of a Chinese D2 sample and it was fragile brittle. Honey Badger out of China that has 58 D2, it's point can snap.
Now the Manly point. A clip point 3 mm spine could bend. But also many had blade snap but leverage force is contextual. Saying that though it could cut and was very popular for those use to .5 carbon blades, a revelation.
D2 really wasn't meant as a blade steel. It was well priced and Dozier managed to get it to work. From there got noticed.
Besides edge retention, balancing steel flex so point that won't easily snap is as important for hunting use. You buy a profile, you want to keep that profile. Protruding drop or spear point for penetration with belly for slicing needs a balance of edge retention and blade toughness.
From the significant amount of data Larrin has posted, I would sayIs there going to be an addition of Magnamax ratings? I see Spyderco is rolling it out now on their manix knife.
Looks interesting. Bookmarked for later when my eyes aren't used up!Been reading this thread on and off for years — it's still the reference I point people to when someone asks whether a steel is "good."
I built a steel comparison matrix a while back and this thread is a big part of why I kept second-guessing it. Mine covers 83 steels across four axes — edge retention, toughness, corrosion resistance, sharpenability — scored 0–10 from published manufacturer figures and HRC ranges. It's free on the homepage of choil.app, no login, no signup.
It's a fundamentally different thing from what Larrin did here, and I want to be clear about which is which. This thread is measurement — he ran the CATRA machine, heat treated the steels, made the knives, and produced numbers that are actually true about actual blades. Mine is orientation — a rough map of where 83 steels sit relative to each other, so someone who's never heard of Vanax can see the neighbourhood it lives in. Narrow and empirical versus broad and approximate. His tells you what happened; mine tells you where to look. If you want the real depth, Knife Engineering is the answer and nothing I've built competes with it.
Where I'd like the criticism: the matrix collapses each steel into one number per axis, but heat treat moves the target enormously. S30V at 58 and at 61 aren't the same steel, and this thread makes that point better than anything else I've read. So — does a single score per axis actively mislead people? Should the axes show a range instead of a point? Or is a four-axis chart just the wrong shape for steel data?
I'd rather hear "this is misleading, fix it" from you lot than keep guessing.
My main question is where do the ratings come from? It shows Magnamax as only having slightly more edge retention than Magnacut, which is wrong. Were these scraped from other ratings sites? Because they're mostly made up.Been reading this thread on and off for years — it's still the reference I point people to when someone asks whether a steel is "good."
Also, I never understood the sharpenability ratings that everyone does. It should essentially be the same as edge retention.
Taking into account the heat treatment is important but difficult to do with respect to toughness. You ideally always want to compare steels at the same hardness. I made a simple model that predicts the characteristics of a steel as the hardness and edge angle changes, but it's just a guess.
Fair
Thank you!Interesting site, Pat!
Good call. I just did that, thanks for the heads up.Might want to ask mods to delete posts 736 (duplicate) and 739…just use the report button and ask for “delete”
