I am finding out that a lot of what knife/steel companies tell us is total bullcrap.
Same applies to telling us that 30-50 year old alloys are premium steels today.
As far as most of the industry is concerned, 99% of alloys are added to steel for two things: corrosion resistance or depth of hardness.
Agreed, but rockwell Hardness its't an abstract number, it does influence steel and edge properties. And in many knives I sure can and do benefit from high hardness.
Therefore, with properly heat treated and tempered plain old 1095 steel you have a strong hard edge.
That is way too generic statement. What is properly HT and strong edge in this context? 1095 or similar steel in the kitchen for vegetables has very different requirements from 12" chopper. I've seen the same steel used in very different knives. Besides, how does 1095 having "strong" edge influences ZDP-189 or any other steel form having even a "stronger" edge?
For the most part, it's good old carbon and heat treat that does almost EVERYTHING for the edge, good or bad.
Is that a reason not to look for improvement or new steels offer no carbon in them? I was under impression that carbide type and distribution was important. While distribution is dependent on HT, carbide types are purely chemical composition. No HT will create Chromium, Vanadium or Niobium carbides in the alloy if they weren't in there to begin with.
Steel companies put out a lot of literature that makes it seem like the newest steels are vastly better, but for the most part I think it's in our heads.
Partly, another part is if you sharpen all of your knives at the same 40+ deg. edge it's unlikely you will really see the benefits of the better steel. It's like buying a sports car, driving it at 40mph on a highway and complaining that it gave you no benefits over your old volkswagen bug
Think about it: 1095 is usually heat treated and tempered back to around 58-60 Rc. 1095 can be heat treated to 66 Rc and have awesome edge holding with the cost of increased brittleness. Now ZDP-189 is hardened to 65-66 Rc. It holds a great edge, but what do you know: IT'S BRITTLE!
So, do I read you right, you say ZDP-189 at 66HRC is more brittle than 1095 at 66HRC, or just as brittle? Or you mean in general "brittle" which is way too vague again.
2000-present: Now we are seeing super steals up to 66 Rc (ZDP-189, M2, etc.) but these knives are usually quite brittle and suffer from edge chipping whenever they encounter resistance.
I have to disagree with that statement, strongly. Without specifying what is that "resistance" you make is sound as if those steels behave like glass, which is not true. I've posted some of the results of metal cutting in
another thread last weekend, and I didn't observe anything similar to what your statement implies. To the contrary, 64HRC edge took less damage w/o chipping on the same material compared to softer steel, it was also easier to restore using a strop.
If all goes as planned, I'll test ZDP-189 at 67 and 63-65HRC on the same medium and perhaps other steel(s), depends how much time I will have.
The last myth: powdered metals.
I am sure there is more than enough hype associated with CPM, PM and many other technologies, but I don't believe they're as pointless as you say. After all, micrographs and compositions are publicly available and on top of that, if they were no improvement, why would all sorts of companies would buy them, forget knife industry, we're not seeing that many pm steels anyway.
Don't expect a 55 Rc 420 blade to hold the edge of a 66 Rc ZDP-189 blade, but also don't expect to be able to bend the ZDP-189 blade and not end up with two knives.
Good point, although, I was never tempted to bend my kitchen knives, and therefore I see no reason why should I settle for 420 or 440C in there, when there are much better choices.
I'm not trying to ruffle feathers, merely pointing out a few observations.
Those observations would have a lot more weight if you had posted a few numbers, brittleness or toughness, wear resistance, etc those are measurable to some degree. Given your statements about field experience and testing, it is surprising you didn't provide anything concrete besides very vague statements.
Where did you see the micrographs? Were they put out by CM by any chance?
Are you implying that in all the time Crucible sells CPM steels, nobody could take micrographs of their steel to test the validity of their claims and you're the only one who found out it was all a lie?
P.S. I'm not sure I understand the general idea of your post though, my apologies tor that. Are you concerned that steel industry is not giving us significant improvements (to which I wholeheartedly agree) or you are just saying 1095, or insert "any old classic" is good look no further, then I strongly disagree.
