I was reading somewhere that the BAD was hardened to over 60, any problems so far with chipping/breakage?
Nobody has mentioned the Anorexic Badgers...if you can find one and afford it...pretty sweet.
Personally, I'm a big fan of the BADs. :thumbup:
I have an use a culti in the kitchen all the time but...
I'm curious from all those that posted it's best for
bushcraft stuff as to why you all feel that way?
Anyone care to share their reasoning?![]()
BTW, I still feel that the BA III is the best knife ever. I just wish I could afford one.![]()
I spend a lot of time in the woods, i've tried all the small Busse knives discribed, and found the Culti to be the best bushcraft knife by far. With a good kydex sheath and some paracord it makes a great neck knife.
The Cultie is the Busse version of a bushcraft knife IMO.
It has a thicker tip than the BAD, and the straight handle makes it a much better knife for this type of use.
The AD handle is not good for many cuts. It is great for a straight push/stab cut or palming the knife while cutting towards self. The straight handle of the Cultie gives you much better control for any cut other than those.
Try this for one example...try making fuzz sticks, or cut meat or anything else while cutting away from yourself with an AD, then a Cultie. You will feel the fulcrum effect of the staright handle that you won't get with any handle with rear drop. Gives you much more power and control on these types of cuts.
a Hack.
