I want to see knives you have personalized youself!
ZT 350 took most of the coating off and rounded off the edges of the G10.
ESEE Izula removed the coating and added red/black TKC scales. Turned a very good knife into a perfect knife for me.
Bush league handle modification on my thrashed Cold Steel Mini AK-47. Just used a bench grinder and some sand paper, but I really like the new ergos.
Before:
After:
... needs traditionals, dang it.
Case large CV Bonestag Stockman, filed the blade kicks and rounded the bolsters, then lowered the tops of the blades. The spay is converted in a semi-spear-drop point.
The pen blade on the old Robeson Stockman (top knife in this pic) was ground down by a previous owner into a screwdriver tip, and works perfectly in electrical outlet screws, doorknob screws, etc. I filed it a little further to square up the tip, as it had been used a lot, by the look of it.
U.S. Schrade 77OT. When I got this one, one blade tip was broken off and the other blade tip was bent. I converted both to Wharncliffe styles, as best I could given the old tools I had at the time. (Old crappy cell-phone pic.)
The Endura 4 here (second from the right) came from a previous owner who had cut a crude but effective "Wave" feature into the top of the blade; it worked, but shredded pockets. I ground it down, then later switched the black scales for the British Racing Green of the ZDP-189 Endura. The clip is from a stainless Endura. The Delica has had the black scales switched out with the grey "Waved" model.
Cold steel spartan: I shamelessly stole Charlie Mike's idea of rounding the top of the blade, then I cut a "Boye Detent" into the lockbar. (This one is a work-in-progress.)
Emerson CQC-10, middle knife in the pic. Scales mod'ed by a previous owner. Very cool mod. I took it further and worked the handle edges down, for more comfortable grip when working without gloves.
Stripped the blade finish on my BK-7, then ground/filed off the ramp. Later I filed slots into the scales to provide a better grip with gloves. A switched out the grip screws with stainless steel slotted screws, heated in a gas flame and dropped in cold water to darken them. That way I can use the screwdriver of my Victorinox Huntsman to remove the scales and get to the matched inside if I need them. the sheath sleeve kept coming out, so I used parts from my junk bin to hold it in. The fancy professional knotwork is courtesy of my son. :p
~Chris
