Really? Has this happened to you?Yes .
Depend on how you use itIf the lock mechanism on my pocket knife breaks or fails while using the knife will my fingers be cut off?
How so?Depend on how you use it
Wait, really? Did this happen to you?100% of the time
If you force against the lock.How so?
No. He's probably just pulling your leg. It's pretty difficult to cut your fingers off just with the knife closing on your fingers. The blade has to go through bone. If it gets you right in between a joint it might give you a serious cut, but even then having your finger completely cut off will be unlikelyWait, really? Did this happen to you?
I guess you've never heard of people with schizophrenia.And an angel loses their wings.
Would the blade usually fold anyways if you were putting the pressure while cutting on the edge of the blade? Cutting away from your body.No. He's probably just pulling your leg. It's pretty difficult to cut your fingers off just with the knife closing on your fingers. The blade has to go through bone. If it gets you right in between a joint it might give you a serious cut, but even then having your finger completely cut off will be unlikely
Correctly. What do you mean? Putting the pressure on the blade's edge and cutting away from yourself?If using the knife correctly, no. If using incorrectly, then all bets are off.
You must have a lot of index fingers.
And apparently you’ve never heard of sarcasm.I guess you've never heard of people with schizophrenia.
Highly unlikely. Look at the design of a folding knife. There's usually a bar running across the frame that stops the back of the blade in position when it locks. If you put pressure on the edge of the blade and somehow break that bar (highly unlikely, unless if you're abusing the knife), then all the blade will do is bend backwards, but it won't cut youWould the blade usually fold anyways if you were putting the pressure while cutting on the edge of the blade? Cutting away from your body.
