Yes I was there. But we glued them back on pretty quick.Really? Has this happened to you?
Buffing wheel?View attachment 1712410
watch out for the small fixed blades too.
If the lock mechanism on my pocket knife breaks or fails while using the knife will my fingers be cut off?
next time out in public look at peoples hands and how many missing fingers you see per hand. bet ya never noticed before....
No. Not usually. If the lock broke while you were trying to force the knife through something at a specific angle, then yes, it could cut your fingers. But probably not ALL the way off.If the lock mechanism on my pocket knife breaks or fails while using the knife will my fingers be cut off?
Once they’re severed and the dog gets ahold of them, whole different story.Chances of loosing a finger are lower then loosing a knife.
(As long as they are attached)
Safest knife money can buyGet an ad10
Depends on your definition of safe. I'm pretty sure the AD-10 is still a choking hazard.Safest knife money can buy
I own a cheap Gerber with a liner lock that, weirdly enough, when I flick it out, pushes the liner lock to the other side of the inner frame. Only when I flick it. Butter knives come in handy.Ron Lake's original intention for the linerlock was that it would fail "safe", bending "in" toward the other slab, and jamming the blade open.
Since then, a lot of people have made linerlocks, and I would not know how to tell if one is going to fail safe, or pop out of the way and let the blade fold.
For all the dubious quality of their heat treat, Columbia River Knife & Tool sells knives with the LAWKS, which actually works the way it's supposed to.
Framelocks likewise, are intended to fail by jamming the blade. I assume it has to do with whether the spring cutout is on the inside or the outside of the frame.
I had a framelock start to unlock on me, just once. It was absolutely my fault. The blade was dull and I was trying to cut 1/2" vulcanized rubber. I applied as much Millwright as I could manage, and started to move the lock because I wasn't applying pressure straight down. This was one of the things that led to my disaffection with this type of blade lock.
Lockbacks and AXIS-style locks can be disengaged by accident, although it is more difficult.
Best advice I can give has already been given: if you are in doubt about the tool's ability to to the job, stop and get the right tool.
What happened to cause it to fail, and what were his injuries?Older brother had to have surgery from a failed lock.
It can happen with dissasterous results.
