WadeF said:
Can someone elaborate on how strong a balisong lock really is? I've seen a lot of people be quick to state the balisong has the strongest lock, but they never explain why that is.
Look at it this way: most folding knives lock the blade by moving something in the way of the blade:
- liner lock: a tab bent on the liner that blocks the rear of the blade tang;
- framelock: a tab bent in the frame that blocks the rear of the blade tang;
- lockback: a "hook" on the lock bar that engages a notch on the tang;
- button lock, a pin that engages a slot in the tang;
- REKAT Rolling Lock: rotating bar that engages a notch in the blade tang;
- Axis lock, the Axis bar that wedges between the blade tang;
- Spyderco Compression lock: a tab bent in the liner or frame that wedges between the blade tang and stop pin.
In each case, the locking member travels only a short distance, so accidental contact can, theoretically at least, disengage the lock.
Other than deliberate disengagement of the locking member, the only way for the lock to fail is material failure: buckling a liner, shearing a pin, tearing out a hole in the liner or scales. Note, though, that this applies to fixed blade knives, too; a blade or handle could break under load.
On a balisong, the handles
are the lock. Yes, the stop pin could shear --
material failure, as above -- like any other locking mechanism, or even a fixed blade; but so long as you hold the handles together, there's no
mechanical way for the lock to disengage.
A balisong isn't as strong as a fiixed blade, of course; it would take much less stress to shear the stop pin or pivot pins than to break any decently-made fixed blade. And on most of the balis I've seen, it would take much less stress to shear those pins than to shear an Axis bar or tear it out of the liners.
So, going back to what I wrote above, it's not the
strongest design, but among folding knives, arguably the most
secure.
