(Manufacturer's recommended heat treat)
Quench: 1525 degrees soak/hold for 30 mins, oil quench
Temper: 1 to 2 times for 2 hours, 450 degrees = 57-59 hrc depending on type of oil you quench with
(New heat treat taken from a mix of ed caffery and ed fowler)
First off this is not how either ed heat treats there knives but this is what I have come up with talking with both of them.
Normalize = 3: 1 day, into house freezer overnight after all three.
Thermal cycle = 3: 1 day, into freezer over night after all three.
Anneal = 3: 3 days, each one cools in furnace over night. no freezer
Quench = 3: 3 days, 1545 degrees for 5 mins, oil is heated to about 160 degrees, into freezer after each quench overnight.
Temper = 3: 3 days, 400 degrees for 2 hours, into freezer after each cycle. This temper should give you about 58-60 hrc with canola oil which is what I use, I am going to up grade to parks50 soon though.
After the first temper I quench in cold running water to help with Ra. The 2nd and 3rd tempers I let cool in the furnace with the door partcially open, I do this to help reduce grain size.
Everything is done in threes because steel will react to all three after that it does nothing.
I also do not do high heat soak times because this promotes grain growth which is the exact opposite of how you want the grain to be in a knife. Larger grain means more brittle at high hardnesses and less wear resistance. The edge will chip easier also.
If you have any other questions do not hesitate to ask. Hope this helps.
I don't think I understand. Are you saying that it's a 12 day process?
