Untitled by Caleb Bender, on FlickrBe very careful using a knife for self defence:
I’ve been doing martial arts since I was a kid but also been in a few too many street fights; you are raising the stakes considerably with a knife. You are committed if you draw one; what might have been a scuffle is suddenly life or death. That knife could be taken from you by an experienced fighter and turned on you.
I know the US is very pro weapons for self defence and the UK (where I live) isn’t but we’ve got knife crime issues.
The very best thing to do if someone draws a knife is get out of there fast. The best thing to do is someone aims an AR15 your way is not to draw a little handgun, it’s to hide.
Weapons up the ante; the dynamics of a confrontation move incredibly quickly. I know because I’ve been there, got the scars.
Be safe, avoid situations, use knives to make/cut/carve/open but it think very carefully about using them for defence.
Thank you all for the advice and recommendations.
As mentioned, I am running in a safe neighborhood and I need a knife for many things because I have abnormally short fingernails. The self-defense use is only a secondary function.
but yes, using a knife for self defense would turn a simple push and curse altercation into a fight to the death. I would not use a knife for self defense unless im bout to die.
i have decided on Byrd Cara Cara 2 mainly for length & weight. The weight at 3.5 oz is bit too heavy, so I will cut parts of the back of the blade to make it lighter & create the emerson wave with the thumb hole. The cara 2 with emerson wave is too heavy unmodified.
Other suggestions are great, but I am not getting a used knife because i am simply ignorant in knife stuff to know when im scammed or jipped, also I dont want to wait days.
when I modify it for weight reduction/emerson wave, i will post pictures.
once again, thank you all for the suggestions and advice!
ps. I think Cara Cara 2 is one of the ugliest knives I have ever seen. But im choosing it for weight/size/thickness and modifiability of the blade.
It's important to remember that ANY encounter in which a person is using force against you could be very dangerous. The first step is to avoid such encounters. When conflict presents itself, deescalate or defer when possible. Unless you have a legitimate need to defend persons or property, try to escape. The ONLY time you should draw a defensive knife or gun, or pick up a sharp stick or brick from the ground, is when you have no other choice.
The reason defensive carry rights are so important is that people sometimes don't have another choice. That's a fact of human nature, regardless of where you live. Bad people sometimes do bad things. It isn't just human beings either. People are occasionally attacked by dogs or other wildlife. In those cases, it is far better to have a defensive tool than not.
The idea of modifying the Cara Cara is interesting. The Wave design can be helpful but a folding knife is still a folding knife. At least you'll have something for now. Something is usually better than nothing. The Cara Cara should handle most of your utility tasks too. Just keep that 8Cr13Mov clean, sharp, and well-oiled. In the meantime, keep those recommendations for a small fixed blade in better steel on the back burner. If nothing else, it'll be fun to explore and check out some different models moving forward.
