- Aug 26, 2010
to buy from the custom shop, probably around 700 but you're looking at a LONG wait
to buy a TTKZ on the forum, probably 850-1000
The test team typically maxes out at $800 on the forums. That was its sticker price but Im pretty sure all the original owners got a better price at blade when introduced so its not uncommon to see them for ridiculously low prices esp if used, I think I saw one for a little over $500 recentlyI want a curved handle one like "derecdesmond " posted pictures of.
How much are those anyway?
Be aware that the Test Team KZ blades had a very robust grind, in other words, a thick edge; and that detracts from the chopping performance, IMHO. After sending mine back to Garth to have the edge profile thinned, it is now much improved.
The deeper biting KZ2 with some of it's blactical buddies.
[/SIZE][/FONT]
Is this service something he offers for all his customers, if so, what does it cost? Because the thickness issue is the only thing really keeping me from pulling the trigger on a TTKZ right off.
Tim, what's that little knife on the bottom of the pic? I've never seen anything quite like that.
I figured I might as well post the question in this thread - for those of you that lack belt sanders, how do you maintain the edge on your KZ/KZII? Do sharpening systems like edge pro and wicked edge do the trick or are the blades simply too big with too aggressive recurves? If you are using a system like the aforementioned, is it a problem sharpening the convex edge with them?
The edge pro will work fine as long as you only work the stone in small sections along the recurve. Thankfully the recurved part doesn't get used in ways that will ding it much so it stays pretty sharp since the belly/tip is where most chopping contact occurs. The stone will follow the belly pretty easily if you center the knife, the hard part is your arm gets tired holding it for so long unless you build a jig for it to stay where you want it. My KZ2 doesn't have a convex edge, it came with a V edge. The custom TTKZ is a really fat convex and an edge pro would work best just to provide a very small edge bevel as the convexed edge will go away if you do more than that. Convex is much better tackled either by hand or with a belt sander.
Thanks for the reply. Have you seen any KZ's with a flat grind? Seems to be so much more convenient![]()
Sweet FNP Tactical, Tim. I am trying to find a dark earth model to match my new SCARS.
The only concern is that of which many are reporting, that the slightly thinner grind of the KZII seems to be a better chopper, but by how much?
to give a rough idea of how much thinner the knives are to each other, heres a thickness grid of the three variations:
Even after being thinned by garth (cs=custom shop) the cs ttkz is still about where the KZII is.
