- Mar 15, 2005
I have never used a Busse,could be I should.3V is definitely more wear resistant than INFI. I couldn't tell you for sure which one is tougher. They are similar as far as potential hardness. INFI is hyped up for its corrosion resistance, but 3V is also very good as far as tool steels go. I think the decision should be based more on the knife and heat treatment than just the steel. For example, if you decided that INFI was the better steel, or even better heat treatment than any 3V knife, if you don't like the look or feel of Busse knives you shouldn't force yourself to get one.
I have a Fehrman in 3V I have used,and a forged 3V Competition Cutter from an ABS MasterSmith that I have never used as I want to keep it pristine,it's the second or third MS blade I acquired here at BladeForums.
Haven't had any trouble with edge retention or corrosion on the Fehrman and it's relatively easy to sharpen.
Heat treatment and optimized edge/blade geometry goes a long way in what you want to do with a knife,imo.
Doug
Edit:Just watched the Browning chopfest
