Well, I am not qualified to determine what were the methods exactly and what could they detect... and Ionbod seems to be convinced it'd be found if it was there, OTOH Germans did detect it...
believe me it, it happens! spill some Coca Cola on a Busse, and let it sit!I have yet to see a rusted INFI blade. So, corrosion resistance is top notch with INFI as well!
Analysis of knife INFI Material
1. Objective
1.1 To analyze the knife provided for material composition and metallurgical characteristics.
2. Background
2.1 provided CAMSS of NC A&T State University a knife for material investigation. The knife had exceptional performance and it was desired to know the possible reasons for the same.
3.1 The material investigation was conducted in the following steps:
· Chemical composition using X-ray analysis
· Microstructural investigations using optical microscopy
· Hardness measurements using digital micro hardness tester
· Visual observations
4. Results
4.1 Visual observations
Visual observations showed that the knife has a complex shape and is possibly air hardened. It is not machined all over as the oxide scales from high temperature are still seen.
4.2 Chemical composition
X-ray analysis using Hitachi SEM showed the elemental composition as below.
Element Weight % Atomic%
Carbon C 0.64----------- 2.87
Silicon Si 0.63----------- 1.21
Chromium Cr 8.12----------- 8.45
Molybdenum Mo 0.85----------- 0.48
Vanadium 0.33----------- 0.35
Iron Fe 89.43---------- 86.64
I have the complete report with SEM Photo's if Jerry wants to see the entire report, email me..
Darrell
Sounds like an interesting report. I was wondering how the samples are prepared for analysis. I had a humorous image of them analyzing the famous decarb layer based on the results.
People always seem to start yelling "troll" anytime someone brings it up but to me it looks like A8 Modified was the base starting point from which Infi was developed. It's really pretty similar as steels go, with a few minor changes.
Whatever it began as, it's sure being treated to get the most out of it for knives designed to chop, and stand up to stuff that most knives would never attempt.
Yet anything that's sold for so much money, is at the center of such passion, and has a made up name isn't really for me. I'm sure I'd love some of the Busse knives from the line though.
I do know I love 3V and have knives from 2 different makers using it. 3V supposedly had it's beginnings in another of my old favorites, Vascowear.
The Busse knives I've seen were very high quality. They are just not my thing , size, weight, or price. I'd guess, but have no experience obviously that 3 V would make a better small skinner, or folding knife. I would love to try some of the other steels like A8 modified, F8, etc. There are a lot out there that have potential for knives.
Are there 2 different INFI steels being used? This one is different from the other INFI composition that I've seen. The other INFI composition does look like A8Mod with a bit of nitrogen added.
"R2" is another one that has people guessing. ( Mr Itou, and this is what is posted over at "japanese XXXXXX XXXXXX.com"
The reputation and demand were terrific! We had so many good words from the users for the extremely sharp cutting and edge retention ability. The secret of this is the finest powdered steel R2 and the forging process. He said he was first using Hitachi Blue steel (Aogami), from which he could obtain a good cutting, but it was rusty. He has then used R1 from Kobe Steel, but it was brittle. Finally, he worked with Kobe Steel to develop new formula, R2 that has improved and exceeded over R1 steels. He also found his special forging process makes it sharper and longer edge retention. Another secret is he uses a large water stone wheel with slow rotating to grind his blades, unlike the normal belt sander grinding. This will prevent over-heating the blade to ruin the proper hardness and its chemical characters.
Thanks for all the info. I figured INFI would be the better of the two. Basically, I want best material possible that offers the best combination of blade performance. A little corrosion resistance would be nice, but tough blade with good edge retention is more of a priority.
