- Nov 18, 2010
Alrighty folks, the man with the plan, the guy who puts the weird into beard, the one we refer to lovingly as "boss", has a contest, so let's make it happen.
1. Beckerheads only.
2. Signup is limited to 20 positions.
3. You have until 06/28/15 to enter.
How this will work: The first 20 Beckerheads to send Ethan their information (Forum Name, Real Name, and Shipping Address) with the words "Inner Tube Challenge" as the subject will be sent an assortment of different sizes of inner tube. The contest is to use that inner tube in any bushcraft, survival, or knife oriented theme in the most creative manner possible. The winner will receive an even larger assortment of inner tube, and a knife, and probably some other SWAG. The losers will be ridiculed relentlessly until they retire from public life, or just acknowledged for their efforts, whatever works best (probably the second options because that requires less effort).
Here is an example of some inner tube brilliance that the boss has become quite fond of, also known as the MacIntyre sheath (spelling might be off there):
Ethan can be emailed at: beckerkt at gmail dot com
Post up in here if you are in and when you have sent your info so we can keep track. Entries will be required to be posted in here as well. If you use a knife for this, make it a BK&T knife. Also, as per usual, neither Ethan Becker, Myself, Ka-Bar, Bladeforums, nor any other entities are liable for anything that may happen due to participation in this contest as by participating you are acknowledging your own personal responsibility in your actions during said contest, be safe, use your head, sharp part away from you, so on and so forth, no purchase necessary, habeus corpus, etc...
No chatting, there will be a separate thread for discussion here: http://www.bladeforums.com/forums/showthread.php/1300267-Inner-Tube-Extravaganza-Discussion-Thread
The actual contest itself will run until Ethan comes up with an idea for when he will be back and not gallivanting around the nation causing chaos, food blisters, and the like.
Put your thinking hats on folks, and good luck!
UPDATE: Cutoff date for entries is the end of the month. You have until midnight (Eastern time) July 31 to submit your entries.
