- Aug 5, 2005
I had bought this "Commemorative" Buck 110 w/Idaho tang stamp [the one in the tin, from Wal-Mart] for a special project [read: I'm going to hack it up], and while taking it apart I thought you might be interested/amused at what it looks like...
This has only been opened 4 times [by me] before disassembly...
The black goop you see around the pivot area is compressed abrasive polishing compound, possibly mixed with some lubricant. This 110 was a trifle stiff to open. Leaving this stuff in there would most likely contribute to premature wear from the abrasive compound.
As suggested by others, in this Forum and elsewhere, it is always a good idea to clean out the knife before using it. I spray mine with WD-40 and work it to get out all this here type goop...I do it several times, until it feels smooth (not gritty), and then apply a good lubricant...TufGlide, MilTech, Rem Oil, or BreakClean...or pretty much any gun oil if I'm lazy...(LSA is great!)...
So...Why are you still sitting there??? Get up, you lazy bums, and clean your new Bucks!!!
Edit: As long as I'm lecturing...You can see here how Buck rivets their scales on...It seems to be 1/16" diameter brass rivets with a 1/8" domed head pushed in from the outside and the liner is countersunk for the rivet. The rivet is hollow for part of its length, and the assembler only has to squeeze the rivet in a press to anchor it. Very clever. No peening necessary (at least not here).
