KeithAM said:Court you post a pic of all of the 110 parts from the disassembled knife, if it's not too much trouble?
chickentrax said:...Court I???...![]()
Yes, I court...![]()
KeithAM said:Dang!I work for a Court, and every other sentence I write at work is the Court this or the Court that...
I admit that I am probably one of the least knowledgable knife knuts here, but I don't think the black goop is anything to worry about unless the action of the knife is actually gritty.chickentrax said:The black goop you see around the pivot area is compressed abrasive polishing compound, possibly mixed with some lubricant. This 110 was a trifle stiff to open. Leaving this stuff in there would most likely contribute to premature wear from the abrasive compound.
As suggested by others, in this Forum and elsewhere, it is always a good idea to clean out the knife before using it. I spray mine with WD-40 and work it to get out all this here type goop...I do it several times, until it feels smooth (not gritty), and then apply a good lubricant...TufGlide, MilTech, Rem Oil, or BreakClean...or pretty much any gun oil if I'm lazy...(LSI is great!)...
So...Why are you still sitting there??? Get up, you lazy bums, and clean your new Bucks!!!![]()
Hair said:And, as always, I could just be totally wrong...
pjsjr said:... I like Q and D. Good luck and keep those post and pics coming. Preston
Scott Hartman said:...I 'd like to order one of the 531/ 532 combo's, when you get to that projector the drop point/clip point combo 110 ...
pjsjr said:I think that I read some where that putting one back together is tricky???
pjsjr said:I believe that the pressure on the pivot from the bolster pin is the touchy part...
Does this mean that you're going to go a little easier on the Buck folks when you get a new 110 with loads of buffing goop inside?chickentrax said:And as I expected, the blade cavity(s) are full of buffing goop!!!![]()
