Tim the Wizard
Street Samurai
- Apr 21, 2012
Reserved for strop photographs.
A little shop talk for those of you interested in strops. We are using Bark River Knives black compound and Veritas/Lee Valley Green compound.
Black is courser and has a particle size that averages 7 microns/micrometers. This is roughly equivalent to a 400 grit Edge Pro stone or a 3k - 5k grit traditional waterstone. Black compound is great for maintaining a toothy edge suitable for fieldwork.
Green compound is chromium and aluminum oxide with an average particle size of 0.5 micron/micrometers. This is about 3X higher than the Edge Pro 7k tape and roughly equivalent to 60k grit. This green compound will restore a shaving sharp edge on a knife that is properly aligned, and is excellent for creating a mirror-like polish on a blade. It does very little cutting but will polish quickly.
In the future, we will also offer bare premium leather strops with no compound that would be appropriate for a straight razor.
Warrior108 said:Just curious but are there any benefits of the Veritas/Lee Valley Green over the Bark River Green and how do they differ? Maybe you just already had that particular green on-hand.
Thanks
twindog said:...Draw any convex edge or blade grind you want. The edge or the blade will be bounded by three points: the apex and the two shoulders. If you connect those three points with two convex arcs, you'll have a convex edge/blade. If you connect those same three points with two straight lines, you'll have a V edge/FFG and all the metal within the FFG will be inside the arcs of the convex sides. That's what convex means.
...If the arcs that define the convex edge are acute, there can be a very large difference between the performance of a V edge and a convex edge, with the V edge cutting much better and the convex edge being more durable. If the arcs that define the convex edge are slight -- think the arc of a circle the size of the earth, there will be virtually no difference between the two edges because the convex edge will be almost exactly a V edge to anyone without an electron microscope.
Andy received an example of TripleT's work.
It's very nice and sharp too!! :thumbup:
Fiddleback said:The HB you sent me cleans hair off my arm very efficiently. Great job.
CAD said:I sent my well used EDC II down to TripleT....let the fun begin!!!
Chris D.
