- Nov 25, 2006
Before I found BladeForums, all I had was an SAK.
Pretty much the same here. I had and still have a Vic ''Ruck sack''. It's probably at least fifteen years old now and it is still a useful tool.
Somewhere in the depths of youtube, is a very funny video of a guy testing a SAK. He wants to show how quick a SAK will dull on hemp rope, and he cuts away. You hear him making comments like, "That should dull it up now", or later on, "I can't believe it's still cutting". He keeps on cutting hemp rope, and the SAK just keeps on keeping on.
Finally at the end of the video, he remarks that it was way better thane thought. Someone with more computer savvy than this old man should put a link in here for that.
Too many steel snobs and knife knuts under estimate the humble SAK.
Here you go:
[video=youtube;peO0akVMNbg]https://www.youtube.com/watch?v=peO0akVMNbg[/video]
SwiftDream,
I would be curious to hear what your cutting test was (as, as I'm sure you nkow, different tests test different aspects of cutting preformance).
Would also be interested to hear how Opinel did (drift).
(...)Is an SAK all you need for general EDC uses?
For me no. I just don't care for them. Not that their terrible there not just would rather have a SOG mutlitool or Leatherman for little more $. I would like to get the SAK Fisherman though to replace the one my grandmother gave me as a kid for the memory and just cause having at least one SAK is nessacary being a knifenut . Especially since there dirt cheap usually.
Absolutely Sir, I totally agree, that is why I test my own edges the way I do use them and the way I might have to use them from past experience.
I tested two #8 Opinels, one in carbon and the other in the 12c27 stainless.
The Opinel in 12c27 was an amazing cutter and had no edge damage. The Opinel handle was much more comfortable than any other folder I tested with the heavy cutting. It slices better than the much more expensive folders imo. The Opinels were the lightest knives in the test. That makes a difference if you are hauling the knife all over creation on foot. All the inexpensive knives in my test with 12c27 were just super, all did better than their carbon counterparts...by a small margin in most cases but still palpably noticeable.
The #8 carbon did not perform as well as the 12c27 did. It was better than the SAKs but did have some slight edge damage and definitely more edge wear than the 12c27. It slowed down into the test where the 12c27 just held its edge better and kept slicing better. Overall it was not bad at all though. It did cut a lot more aggressively than the SAKs did.
I do a lot of food prep out there and have tested all my knives that way over a normal course but heavy wood slicing is important to me from past experience. So my test was carving two hard, seasoned woods, mesquite and acacia. Can I get down into dry portions of very tough, seasoned woods if I have to build a fire in very wet, cold conditions. So each knife was tested on the same woods in the same way just for my own information. I carved down to the same depth with each blade in the test.
I tested some fixed blades too as I like to have a small but capable fixed on me for both strength but also some of the messy food prep where fit and finish really counts when cleaning. On the long trips I'll cook some fancy meals with chicken and the like so easy and thorough cleanup is imperative. I also want a blade that will cut through chicken bones with no edge damage. Most food prep is not too hard on an edge but some can be. For my usage of these tools these are the practical tests but others might need different tests for their own practical usage.
That was my initial reaction as well. But if you watch closer he does actually use the whole edge of the knife most of the time.Look at where he is actually cutting the rope, where the edge curves near the tip. Then he slices the paper with the long straight edge he has not cut any rope with...and is so amazed...and he just keeps doing this over and over. You can see where the paper hangs up when he gets the slice up near where the edge did cut the rope so he just starts back down the virgin area of the edge to finish it...again so amazed...the area where he actually did the cutting was extremely damaged. And of course he was having a hard time getting through the rope which didn't surprise me.
The only thing I'm amazed with is his lack of spatial perception.
Fiber reinforced pneumatic and hydraulic hoses are some of things I apply a lot of force when cutting.
But even tasks like cutting the heavy tarpaulins and ropes we use is best done with a fairy strong tool, I prefer a fixed blade to a folder, and would chose a folder more substantial then a SAK if I had to go that root.
In the woods, making a camp fire or lean-to, I often apply more force to a knife then I am comfortable using with a simple slip-joint like most SAK's
Don't get me wrong, I like SAK's and have been using them all my life, great tools for light duty cutting tasks.
And, as I stated earlier: "For folks who only tackle light duty cutting tasks I imagine it might be all they need."
But not for me.
Big Mike
Check out the SwissBucks that were made some years back by Wenger. All(?) had clip mains.I don't like spearpoints, but if they ever came out with a model with a main blade sheepsfoot or clip point, I'd be first in line.![]()
No, I do not believe that's higher than it used to be. Victorinox heat treat different tools to different hardnesses. If you read 54RC what tool was that for? The only place I've ever read of Victorinox blades at 54 RC are in various posts of yours in different BF threads.
Blades are listed as 55-56 RC.
Wood saws, scissors, and nail files at 53 RC.
Screwdrivers, can openers, and awls at 52 RC.
Corkscrews and springs at 49 RC.
