Yeah I'm interested in what machinery can't cope. You change the belts on the sanders. The customer would pay for them anyway. I saw the video's of the GEC shop and the only thing I assume they would need to change is the blade shape punch?
I don't mind the brass either, having them all flush, now that might be a nice touch...Also, I personally don't have a problem with the brass liners or pins.
Is there really such a disdain for them? I haven't been a traditional knife person all that long, but they seem fine and look nice when they patina.
Only by a very vocal few!Also, I personally don't have a problem with the brass liners or pins.
It doesn't exactly work that way. Switching steels isn't just ordering the steel.
Punches, drill bits, little things. Processes like heat treating and possibly blade etch for have to be looked at.
Problem is, metals act so differently when you change types. What produces great results on 1095 might not be so hot on an exotic stainless.
And when you're dealing with slip joints, you have to take springs into consideration. An elmax back spring would probably not be a carbon copy of a 1095 spring.
Totally correct. For a company set up to process carbon steel to swap back and forth from carbon to stainless is a pricey proposition. I don't have a relationship with a knife company, but I am an materials engineer and work for a manufacturing company which makes precision parts from aluminum, steel, stainless steel, nickel alloy, and titanium (not that we use much plain steel anymore, but we still know the protocols). I still spend time on the shop floor. I have performed time studies and priced out manufacturing changes.
ANY stainless containing carbides is significantly harder to form and process than carbon steel. Doesn't have to be fancy PM alloys. Even 440C has these requirements. It isn't just sanding belts. Machining takes longer and creates more wear on tools and even the jigs than carbon steel. That means tool life is shorter, so tooling cost is more expensive. The heat treat for stainless is also more expensive. The chemicals for electro-etching the blade are also different, but that's a relatively minor issue. Swap them out, cut a new stencil and off you go.
Housekeeping is another issue for a shop that processes both carbon steel and stainless. Stainless is stainless because of a thin oxide layer on the surface which acts as a barrier to water and oxygen. If that oxide layer gets contaminated with carbon steel, the barrier is breached and you get corrosion issues. We handle it at my company by dipping the parts in nitric acid after the manufacturing processes are complete. Not sure how knife companies handle it. But one thing for sure, you want to use a completely different set of belts for grinding stainless than you use for carbon steel, so that you don't contaminate the stainless. All of that costs money. A lot of money.
In manufacturing, there is something called, "fully burdened labor cost". That means that to the amount you pay the worker is added the overhead costs of machine maintenance, electricity, real estate taxes, the mortgage, the cost of a web site, the cost of a secretary, the cost of the phones, etc. Most outfits have a fully burdened labor rate of $120 - $150/ hour. Let's call it $120 for GEC. So all of these things which require more time in order to handle stainless greatly add to the cost of the knife. Change a sanding belt? 15 minutes + another 15 to change it back when you are done? That just cost $60. For a run of 50 knives, just that one small change added ~1.20$ to the manufacturing cost. Now add profit for GEC and add markup for dealers and all of a sudden it added $2.80 to final price paid by the end buyer, and that's just to modify one minor operation.
I said all that to say, "It takes more than just buying different alloy to change the alloy in a knife from carbon steel to stainless."
I like what GEC is doing, and how they're doing it.
You have to remember, they make their own blades from soup to nuts, and heat treat them themselves, if I'm not mistaken. Putting an exotic steel into ancient machines and getting away from a steel they are very adept at working with and is suitable for the style knives they make is a little questionable. They'd probably have to make some tooling changes and do a lot of experimentation to use something like Elmax. That doesn't sound so bad, but GEC's profit margin isn't exactly huge, I hear.
I'm fine with GEC doing what GEC does. If I want something else, I'll buy something else... but that doesn't happen very much.
I'm pretty sure GEC uses Peter's Heat treating just like Queen.
Dave
Re: GEC; we can talk about the tangibles all we want, but what you can't get anywhere else is a certain sense of SOUL!!
There are wonderful knives from America, England, Italy, France, Canada, Switzerland - on and on.
But when you track the evolution of cutlery through the American industry, it peaks at GEC!!
It's taken generations to evolve to the feeling of owning many of GEC's knives!
Not perfect from a dispassionate/clinical view, but celestial from a human perspective!!
I like that GEC provides employment in a small town that needs the jobs. I like it that the guy in charge loves traditional knives like I do. I wouldn't change a thing!!
GEC could "dip their toe in the water" by doing just one run per year in an upgraded steel at an upgraded price. People pay 3-400 bucks for the annual Bose Collabs from Case, so there is your price point. Put your two or three best cutlers on the project, use all stainless and nickel silver with something like Elmax or M390 and all the bells and whistles. I don't think there is any doubt they would sell.
GEC is in a league of it's own here in the states. The only comparable stuff in terms of quality at the same price point can be found in Europe.
Renaud Aubry's stuff is better than gec imo but the patterns might not be to your taste. He also offers what are considered premium scale materials at a crazy low price. There are some close up photos of his work in this thread:
http://www.bladeforums.com/threads/dutch-forum-knife-2012.939283/
I agree re: Renaud Aubry's knives, I have a Navette slippy from him, and it's perfect in every way, and very affordable.
