STR said:
... this pin keeps the lock from going all the way across the back of the blade and creates a physical stop
I can see this preventing the lock bar from traveling, but since it wants to, isn't the mating between it and the blade less than optimal?
knifetester said:
If your Sebenza is so over ground (1/2 of spec), why don't you return it to CRK for a blade exchange?
This one suits me better than the spec'ed grind, I would even have it thinner if possible. The U2 that Krein reground has a deeper grind. I usually EDC it along with the Fulcrum and something of similar class to the Paramilitary.
...why did you go for the new S30V Sebenza?
Because I was curious about the steel, specifically I intend to compare Reeve's heat treatment to Wilson's.
And yes of course different people have different desires, there is nothing inherently special about the demands Patrick places on the knife in construction work, he in fact uses more care than most because of his experience with past knives.
If I gave any other member of the crew the knife, told him this was promoted as a "hard use working knife" it would get mangled before the day was out, it is simply a cross section issue, even if it was as spec'ed this would be the case.
Plus the first time it jammed solid and had to be pryed apart its life would be likely to get really uncomfortable very fast. Their perspective of course is very different than someone who sees it with a $325 price tag.
But in general I would find it hard to argue that heavy grip pressure is rare on knives used for heavy cutting, it isn't like the work that Seth described in the above can be done with a really light grip, nor is it something that I would bet on doing with a thin edge hollow ground knife.
It is for reasons like this I don't call it a hard use design, other people are free to draw the line anywhere they want, just be clear what you mean with exaples of work done and there is no real issue of contention.
-Cliff
