Cliff Stamp
BANNED
- Oct 5, 1998
From doing this a few times to check the "stick" and general carry and use, including a few dozen intertial openings, the lock engagement is more than 4/5 across the tang. It has wore just as fast as the Kershaw Vapor, which has actually seen far rougher use as the blade profile is stronger so I use it to twist split wood and such.
-Cliff
I have no personal interest as EDC users in liner/frame locks outside of light precision cutters, even then I would prefer a more secure lock because even very slim and narrow blades like the Vapor are capable of doing an awful lot of utility work but are restricted by the lock releasing.
The Military was then used extensively in the kitchen. Through the tip it easily cut cut meats and trimmed fats, even tomatoes and plums were smoothly cut without excess slippage. Hard synthetic ropes were no problem, and various fabrics, paper, cardboard, and rubber tubing were also neatly cut.
Pointing some ends on a hardwood dowel (basswood) the Military required 3.78 +/- 0.54 slices. The performance was high due to the thin blade stock and thin and acute edge bevel, combined with the excellent leverage due to the edge being fully sharpened right to the handle. With a 50 lbs push, the tip sank to 266 +/- 8 pages into a phone book, with a hard stab (icepick grip), the penetration was 681 +/- 35 pages.
On binding vegetables like carrots and turnips, it continued to do well. . .
The Military easily handles light vegetation as this mainly requires just a very sharp edge. . .
The Military is readily capable of roughing out large amount of wood in a short period of time.
For carving notches and in general shaping of wood the Military works well for hogging off material and precision carving.
You list specific tests for cardboard, carpet, etc.The Military was carried daily for an extended period of time (months) and used for all cutting chores.
In contrast, on this Military the liner lock held secure under "white knuckling" as well as various spine whacks. Heavy torques on the blade (split a piece of 1x4"), did not disengage the lock, nor did a combination of torques and vertical loads. In short the lock was stable during all testing, and held up fine under the heaviest of the dynamic cutting.
In regards to toughness, I was mainly concerned about tip strength as the point is very fine so I spent some time ramming it into wood, twisting it, and pulling to the side. I also did some light prying by popping out heavy staples and such. I did not repeat these tests with the Endura as I have broken the tips off of other stainless folders (440C) with thicker point doing similar work.
I wouldn't worry about the bushing, it's plenty stout. And they don't really take any of the stress; the pivot screw does.STR said:I'd be a little afraid of what twisting motions could do to the bushings on the Sebenza. If they are sensitive enough for Chris to warn against hard flicks opening the knife you have to wonder. Do I understand that correctly, or is it the lock that is the sensitive part for hard flipping to open the blade?
I still think the safest bet is to use your knife what it is intended for and if you need an axe, tree stand step, trowel, jackhammer etc... get the right tool for the job. You will probably accomplish it much quicker and with less damage to your knife or yourself. Perhaps I am missing something here though.............
STR said:If they are sensitive enough for Chris to warn against hard flicks opening the knife you have to wonder.
chris in mo said:I wonder how many ancient cultures would see one of us hammering a knife through a log and shake theire heads about the poor moron who does not realize that an axe head should not be shaped like that and could show us how to do it correctly with a properly selected and shaped rock!
knifetester said:Take the knife apart, reassemble then see what it is. On several Sebenzas, this would "reset" the lock so that it travels much less across the tang.
...you have basically writtent hat the liner lock is such an insecure and unstable lock design that it is almost worthless.
If some liner locks fail, and some don't, then perhaps it is not a problem with the Walker design, but rather a problem with execution.
knifetester said:I would be happy to baton a bit with the framelocks and an Axis lock, hwoever it will take me a week or so before I have the free time.
Scott Dog said:...is it reasonable to expect any lock to hold versus a fixed blade?
I can unlock the Military with wrist torque in woods, it takes more force than to split a piece of 1x4" as used in the review, it can even split birch flooring, however as I move to thicker wood the lock will release long before the blade is in danger of breaking, I'll see if I can't get a couple of pictures put up later this evening.
1) the frequency of problems is high compared to other locks
2) they can pass tests and then fail them suddenly at a later date
3) some of them fail trivially under very low impacts/torques
otherwise the design is inconsistent.
