Please add a flipper! It makes for awesome deployment, and a great guard.
5+ inch handle is fine by me, I have pretty large paws anyways. Just for an idea, I can hide my skyline in my fist...
I discovered something pretty cool on accident the other night sharpening my skyline, the thumb studs are th correct length to set the bevel for the edge! Just lay on the stone so the edge and stud are both touching and it is the same angle! I put one layer of e-tape over the studs so it didn't load up the stone with softer steel and it really helped me freehand by haveing a reference point for angle, just like my straight razors. I don't know if you can pull that off within reason on a thick blade, but for the thickness-height ratio of my knife it worked!
I think if you did a swedge on the forward half of the knife the stabbing resistance would go down without compromising strength. Hand lapping for flatness on the pivot is a good idea but I don't like it polished mirror smooth. You need a certain amount of "roughness" to hold oil anyways. I assume your going to use PB washers? Seems the PB and teflon washer combonation allows just a tiny amount of blade play. A thought on back spacers, stand off are great but as Kevin and I found out on a couple of RAT1's can cause all sorts of alignment issues with blade centering when disassembled and reassembled. I think if you did a G10 one for a portion of the back with stand off on the butt to allow debris removal would accomplish you rigidity goal, reduce cost and eliminate complications.
Just my two cents...
-Xander
Thick blades can cut well, it's just a matter of having the right blade geometry which I know Daniel has a good handle on. Jeremy Horton also understands how it works, here's some edge shots of the TAC-4:
It really is as sweet as it looks. Bring on the beefiness DF!
I'm in regardless of final spec, so please put me down as a confirmed order. If I had my druthers, The first thing I'd ask is that it be between 3-3.5", no more, no less.
+1 i vote for something more along the lines of h13 holds an edge better and is tougher than s7.
if you can you should do bearings for the bushing
make the ti scales .188 thick. (its already big whats another .64 inches)
make the stop pin visible like on hinderer designs or even a thumb stud like the 560 but make it useable and make sure they aren't so big that you can sharpen your edge in front of them ( i don't like oval holes in blades)
lastly put a stone wash finish on the Whole thing and not like a cheap stone-wash I'm talking so good of a stone wash that you get pissed at the knife because it wont wear
and a given you must carbidize the lock-bar
S7, 3V, D2, or even M4. Don't really need anything tougher than S7 in a knife, especially in a folder. I'd give up some of the toughness of S7 to get it up in hardness to better hold an edge, and the Havok X is proof of just what that can do. As beefy as this folder is going to be, I'm not going to be chopping or prying with it. High hardness and edge retention is what I'm looking for in a folder steel.
0.155" thick Ti works for scales, it's the same thickness Jeremy Horton used on my TAC-4 and is just right. It's thicker than my ZT0560 despite the ZT having thicker Ti (0.172") because of the blade, and makes the TAC-4 feel better in-hand. Nath is customizing an Emerson for me, turning it into a framelock, and he is using 0.160" Ti only because the other option was 0.125" and I think that's too thin.
Another key element, the pivot. Bigger is better, and please no funky ones that need a special tool to adjustand at least T8 torx to hold it all together. Overbuilt. Make mine with a thumbhole.
This might be silly... can you HT them with hamon on the non-stainless steels?
And of course there must be stonewash!![]()
Well I can't pass up a Fairly Folder so I'm in. 3" to 4" blade for me, 4" is legal limit here.
Well, I'm in whether it's S7, M4 or most any steel choice gets the popular vote. Would prefer a blade no longer than 3" for legal California carry.
me to, I didn't know that (I should have I know)I'm glad you mention CA legality, it seems a lot of states have a 3" law.
I say fo shisel on the chisel ! Just make mine lefty and I trust you on the rest.
Daniel- Will you offer a half Ti, half G10 handle?
I'll be happy with either steel, and I know there is no point to differentially HT a folder blade... It just would be cool!
My understanding is that if you stonewash a DHT there will be two distinctive finishes on the harder and softer parts.
After stone washing some of my factory folders i noticed that oil/lubricant stays in longer and the opening is smoother.
A 3ish blade is all I need in EDC folder, and I guess most folks don't need more than that...
I agree, in fact for strength fully hardened is better in my opinion, no grain boundaries and pearlite. I do think there can be benefits from a hamon or differentially heat treated blade though, you can bend a bent one back to straight sometimes and in battle a hamon can stop a tear in a blade from making the blade break. Of course this is a vast topic subject to lots of debate, I can see both sides though.
...you can differentially harden a lot of steel types, only some will have enough difference to show a hamon. My older 5160 and O1 blades were differentially hardened and they show a straight quench line when etched. Phill Hartsfield was able to show a hamon of sorts in A2, who knows how!
True on the tumbling, the different hardnesses will tumble differently. I'd like to try one eventually and see, that would be cool. Bead blasts can also have a cool effect but I have no blaster, that would be fun to try as well.
Again, there is no need for it, I know, but some of the hamons makers here post pics of are really spectacular. Add the stonewash, stonewashed Ti handles and you get a really elegant and subdued knife...![]()
Sounds good, thanks for the input!
I used to like in St.Thomas USVI and carried a machete everywhere when I was hiking, lol I bet I would get some looks here!
