Dan, all of these blades, with the exception of 3, are of the JD5160. I wanted to forge them more or less during the same time (both the 52100 and 5160), so I could get a better feel of the differences. Don't have a whole lot to tell you yet, except that my forge temp registered about 1750-1800F. The 5160 does move better and is easier on the press (I judge this by noise of the pump only, possibly not the best, but it's a comparision none the less). For some reason, the pressed out bar of the 5160 was much shinier, brighter, slick than the bar of 52100. This may not make a bit of difference at all. Seemed as though there was less scaling of the 5160, although trying to count pieces of scale isn't very scientific unless it's weighted, and I didn't have the equipment for that. I normalized all blades 3 times using my Evenheat set at 1600, then put it in vermiculite for the heck of it, instead of leaving it out to air cool. I wasn't actually trying to "anneal", just normalize. The 5160 seemed to grind easier, but was probably a toss-up. Now, I didn't break any bars open and look at the grain (if I can see anything that small), maybe next time. The 52100 blades were all in the 40's the next day, and the 5160's were in the high 30's. I've never had my Rockwell meter calibrated since I got it used, so really I'm not sure about the readings. One little blade, instead of putting in the vermiculite, I went ahead and edge quenched for fun. The file test was very positive, and RW showed 54 on the edge and39 on the spine. (again a non-calibrated unit).
I have more to do over the next few days, and will keep notes of futher progress. For the time being I'd like to say that to me, the 5160 was easier to work, and squeezed like a marshmellow when hit with about 40,000psi. The 52100 strained the press more, didn't press as far each time, but was still pretty close. These two steels are going to be my primary steels, so I'm trying to learn as much as I can about each(for damascus I'm using mostly 01 and L6 now). I like them both, but I am pleased that I'm not having any trouble (so far) working with the 52100, I really like that stuff. Wish I could go to Ed's for a week, not in the cards though.
