- Jan 25, 2015
The steels I like are great.
The steels you like are junk.
Well said!
well as another thread just inspired me- i really dislike d2... The corrosion resistance is horrible, and the prices some manufacturers are demanding when clearly better tool steel alternatives are available boggles my mind. At least go pd1!
I'm not complaining on it's use in a composite leek at that price point, but a $300+ folder in it i just can't understand.
The steels i like are great.
:d
Nothing? Elmax is good to go? That's good news.![]()
I'm curious to know what thread you are referring to. There was a thread here a little while ago specifically regarding the corrosion resistance of D2. The consensus was that it did a good job of resisting rust/corrosion (it is a semi-stainless steel after all). I was one of the people who commented from personal experience that my D2 knife has never rusted. And that's despite years of use, and frequent exposure to sweat and hand oil.Well as another thread just inspired me- I really dislike D2... The corrosion resistance is horrible, and the prices some manufacturers are demanding when clearly better tool steel alternatives are available boggles my mind. At least go PD1!
I'm not complaining on it's use in a composite leek at that price point, but a $300+ folder in it I just can't understand.
Do you have any personal experience with a knife made of D2? If yes, I'm curious to know which one.
yes actually my d2 leek- it was cheap enough so i didnt sweat the rust spots but it was enough to turn me off from buying a more expensive blade using the same steel... ive also since seen many charts showing pd1, niolox and sleepner being better than d2 all around.
oh the thread i was reffering to was the "overpriced fixed blades" one today
S30V and VG10 on my spyderco knives are great recently sharpened a zt elmax. Bit more time to sharpen but damn its sharp for such a thick blade. Lets see how long it stays
I have a spyderco dodo made with s30v. At first I thought it was a useless knife, stuff gets in the ball bearing lock, it has no straight point . . .
At work though it's practically indispensable. Actually it IS indispensable, I got another! Its not so much the steel as the shape. It's not long and pointy so it doesn't scare the sheeple I use it to open boxes and remove labels so I can see what's underneath.
I work in a lab so it's not really "heavy use" except for opening all those boxes. It's the serrated version and can always open a box. I use a sharpamaker to keep those serrations sharp. The straight part on the end is so sharp it went through my scrubs and make a matching shallow cut on the skin beneathI didn't feel a thing!
That's my only experience with that steel. Oddly enough I have an old brass bolstered kabar folder with 1095 steel. I hated it. I could never get it really really sharp. Not sure what the problem was, I had not trouble with other knives. I avoid 1095 steel.
My D2 bark rivers can skin and dress several deer without needing stropping. Not sure if it's the steel, the heat treat, or the grind but they are my favorite fixed blades.
My Queen mini trapper in D2 gets lots of tiny corrosion pitting spots on both blades.
How is it being used and maintained?
I have much more corrosion-pron knives that have no pitting after decades of use outdoors. But I wipe them dry when I'm done and oil them when I get home.
PD#1 in most cases will have less corrosion resistance than D2, and CPM D2 like the Leek. Niolox is a stainless and not as tough or wear resistant as PD#1. The steels are all pretty different and not similar except that they are good steels and sometimes used in cutlery. Strange comparisons. It's like comparing BMW, Ford Truck, and a Suzuki road bike. Different uses . Throw in the differences that come from how they are heat treated and tempered and it's difficult to see comparison.
Their attributes are balanced out so differently calling one better or worse can only mean you for your uses. That's what better or worse is though. Subjective.
joe
It never gets wet. It got that way from being carried during the summer and probably from being handled. I wipe the blades off with my shirt or a clean rag/paper towel or something after use. In the past I oiled the blades but it made no difference so I stopped. By tiny pitting I mean really very tiny, very shallow spots, like if I used the tip of a thin needle to make small indentations into a soft material. It's very minor but it's there. Flitz doesn't remove it.
I have another Queen knife in D2 that I carried and used only a handful of times. It has no corrosion at all. Hot, humid summers in the great plains have caused most of my blades to show corrosion spots from just being carried in my jeans pocket. CPM-M4 got a bunch of surface rust from being in my pocket for 2 hours outside. Kershaws with their horrible bead blasting in 14c28n, 8cr and even the bead blasted elmax on the speedform 2 all developed surface rust within a couple hours. My Domino in CTS-XHP even developed surface rust in my pocket from carrying it in the summer. I clean them all up with Flitz and they're fine, but basically every steel I've used except for H1 will rust in the summer if I'm carrying it in my jeans pocket outside.
