I've never had issues sharpening S35VN but can't say the same for M390 and Elmax (although I have no problems with their use, edge retention and corrosion resistance)... I wouldn't purposely stay away from either, but I don't seek them out like some do. I actually choose S35VN when the option presents itself simply because I find it cheaper than most high end alternatives (especially M390) and like the ease of sharpening.
Now to your original question, I stay away from S30V simply because I see S35VN as an overall improvement on it... It's a fine steel, but knowing an arguably upgraded version exists in S35VN, I can't bring myself to settle for it.
If you're trying to use a traditional or (for lack of a better word) "cheaper" sharpening system, then M390 won't get along all that well with you, especially when you first start sharpening it.
I find M390 MUCH easier to sharpen than the vast majority of steels in the same category (with the exception of Vanax 35, though it has special properties), and much easier to maintain in general as it takes well to a strop and a 15 degree per-side edge performs insanely well.
M390 is my personal favorite for stainless steels in an EDC, primarily because it does everything very well, while not being too good at one perticular thing at once. By comparison, S90V holds an edge longer than M390 generally, but is much more tempermental if not properly heat treated (will become very chippy), and is extremely hard to machine and sharpen, while only holding a fine edge for a short time. It holds a very good working edge and like I said will hold it for a very long time, but does not like a fine polished edge, and is extremely hard to polish in the first place.
M390 on the other hand works very well polished or with a coarse edge, and will hold an edge for almost as long as S90V, but in either a fine or coarse edge. In addition, it has an insanely fine grain structure, so it takes a polish quite well for a high-carbide steel, and it is much easier to sharpen than most of the steels that fall under the banner of "super steels". It also has exceptional corrosion resistance, and is much easier to machine than S90V, S110V, Elmax, etc, while still maintaining good toughness and overall performance. In addition, you will not find a stainless steel that cuts more agressively than M390 out there. It's small but extremely hard carbides make it just devour most materials without effort.
S35VN is still a very good steel, and is easier to sharpen, but I would take M390 over it any day I can. In terms of the knives I've handled and the different heat treatments I've seen for both, M390 will outperform S35VN in all categories seemingly without fail. The only steel I find is overall better than M390 is sometimes Vanax (aka Vanax 35), but it is much harder to get, much more expensive, and generally isn't going to be in a knife most people would be willing to really use. Which is unfortunate, because it is an amazing alloy.
Keeping with the thread, I do not like S30V or most of the 440 series of steels. S30V has chipped on my much more than I like to admit, and like others have said, overall S35VN seems like a better steel. The 440 series of steels are overused, and while 440C has it's uses, there have been numerous improvements to it in various forms, and those are much better choices to me than the original. It works fine for some people, and I respect that, but definitely not me.
Another that bothers me, but I certainly don't hate, is CPM154...which I know may get me in trouble with some people, but its true. There are way too many insanely expensive knives in CPM154, and while the steel is good, that's about it. It is very good at taking finishing work, and is easy to machine while offering good edge retention and corrosion resistance. For knives that are not entirely meant to be used, but more admired with the potential tobe used, yeah, it works very well. For me though, I don't buy a knife without at least the inention of using it. Because of that, I would much prefer the use of a steel like Vanax, M390, M4, 3V, S110V, S125V (though that has its own set of issues), etc. on a knife in the range of $1000+.
Again, I think on most knives, the steel is fine, but once you get into the more sought-after and prized customs...no.
End of rant...my fingers are a little sore form that
