These are the the pics I sent to them showing just how much was ground off the heel of the blade. I also included a photo of the really bad lockface grind. This is how it was returned to me after I had just had sent it to them because they press fitted a too large thumbstud into the blade causing a stress fracture between the thumbstud and blade spine. The knife was basically brand new when I sent it to them and this is how I got it back. I didn't include pics of the bad swedge grind or scuffs because I didn't want him to think I was nit picking, but the knife I sent him had even swedge grinds with no scuffs of the blade. Literally, it was out of the box for a couple of days when I saw the crack. I talked to the guy over the phone and he asked for pics, so I sent these and the following is the response:
"Let me first apologize that I am just now getting back to you at the end of the day.* After going over the pictures, I do see and understand what you are seeing with the knife.* Let me go over the two issues individually.
1)***** The sharpening on the blade edge
I can see where the edge bevel does appear to come up above the choil.* This is caused by the sharpening altering the angle just as they reach that choil.* You can see that it creates a much larger edge bevel and makes it appear higher up (it looks like there is as much bevel above the top of the choil as below), but the edge bevel on rest of the knife is pretty much lined up with the top of that choil, which is about where it should be.* So while it does have a visual look of having less choil, the blade does still have plenty of life in it for a long life time of use.
2)***** The frame lock not sitting square with the blade
This is actually fairly common, so long as the lock bar is holding at the front most edge and not the back most edge, the lock bar will have a solid hold over the blade.* The blade should have no play at all and have a solid lock up.
With this being a limited edition and hand crafted knife, there will be a number of slight variances, as one would expect with custom knives.* So long as these variances do not affect the performance of the knife and are within our set tolerances, there is little that can be done to them."
Then his name and contact info.
He tries to say that it's a "handcrafted" knife so I should accept the bad grinds that removed WAY too much metal and a lockface that is obviously not par for a 300+ dollar knife. I don't agree. What do you guys think? Should I accept shoddy work on an expensive knife from a company like KAI? Makes me not want to buy a knife from them if they're going to send a knife back that's in worse shape than it was when I sent it in.
And thanks to the mod who unlocked this thread. I still don't understand why this thread is in feedback because it's about advice, not a review, but whatever. Hopefully more people see this than all the feedback threads that are still in the general discussion forum without being moved.
