Is the cf completly smooth on this knife?
I don't know that might have been a deal breaker .then again I really want to try this secret secret hush hush vanax 75. The o777 I might be taking off my preorder list though .why use n360 in a four hundred dollar blade when it has less wear resistance then n690 and equal to 440 .that's one I really don't get and hope changes before they start making them
No secret hush hush that I know of. Did you compare V75, and N360 steel spec's? Your thoughts on the two?I don't know that might have been a deal breaker .then again I really want to try this secret secret hush hush vanax 75.
Why? N360 is a new high end offering for the knife community, machines like a dream, worked well in a CB environment, has extreme corrosion resistance, and is ZT tough.why use n360 in a four hundred dollar blade when it has less wear resistance then n690 and equal to 440 .that's one I really don't get and hope changes before they start making them
I'm getting both, as well as the 0561 flipper. Try not to get too sucked into the steel obsession. You have to consider the design of the knife and the task in mind. While the 777 is more of a luxury item, I would expect it to be able to handle a certain level of hard use given its release under the ZT name. A high carbide steel with 9% vanadium and 20% chromium isn't something I'd expect to hold up to hard use without chipping, 3rd generation PM or not.I don't know that might have been a deal breaker .then again I really want to try this secret secret hush hush vanax 75. The o777 I might be taking off my preorder list though .why use n360 in a four hundred dollar blade when it has less wear resistance then n690 and equal to 440 .that's one I really don't get and hope changes before they start making them
Yes, they have to heat treat similarly or else either one steel will end up being brittle or soft as butter. Though I'm not too crazy about the use of CPM-D2 with Elmax or M390, as it rusts pretty easily.I remember reading somewhere the steel which is the spine sometimes won't work with all steels. Does that make sense? And what I'm repeating might be hearsay.
Good comeback...
If the steel flies over well, I'd put my vote in for a ZT fixed blade in N360:thumbup:.
