- Oct 7, 1998
It's already there. And has been for quite some time. I personally know a knife maker that has his blades water jetted, as is the titanium frame, and g-10 scales, and carbon fiber scales. The blades are double disk ground. The clips are supplied after market, as are the screws, bushings, and bearing. He gives the locking bar and or the tang a light stoning with a gunsmiths trigger stone, bead blast the blade and liner, screws every thing together, and etches his logo, then sharpens. Quite literally all the hand work he does is the stoning of the lock, and the sharpening. Total time to build a "Custom folder, 15-20 minutes. There is much more work in a kit knife. But he gets north of 40.0U.S. for them. If he has the supplied parts in stock, he can produce up wards of 20 and more knives a day. The only thing missing at the moment is enough customers to by his production. Did I say Production? Hummmm!!! Or is it really hand made. Or at least hand screwed.:jerkit: Or is it just the customer the one being screwed. They can get the same technoligy form Benchmade. It may be a small factory, Or shop, but it is still a production piece. Pure and simple. It world be a great 125.00 to 175.00 knife!
What knifemaker would that be Mike?
For that matter Shing, what factory are you talking about? Were you on the production floor? Some makers of kitchen cutlery are fairly automated – however even in that market, LOTS of handwork go into the knives. You're saying they dump parts in one hopper and folders come out the other end? I don't believe that. Let's have the name of this factory!
Or Mike, even better, what's the name of the waterjet cutting company that can cut out a blade blank complete with the 8 degree angled contact surface on the lockup face of the blade? That can cut the pivot hole reamed to size? And let's not even get into tapping the parts and locating the holes and countersinking!! Mike, what waterjet cutter countersinks after tapping!? I have a good deal of water jet experience and the machines I've seen can't cut anywhere near that well (the cut edges are slightly angled in a bad way due the the break out of the jet stream on the exit side), so the contours have to be cut oversize and machined to final tolerances ... see RJ's post above.
Mike if that were possible, that would be the way major knife companies like Spydeco made all their knives... but it's not possible and they don't.
