afishhunter
Basic Member
- Oct 21, 2014
Are the knives in question by Gerber?
I thought I saw in the OPs post that the dulling of the blade while idle was explicitly not due to corrosion but some magical properties. I think the reality is that corrosion and thermal property changes might effect the edge's exact sharpness. This all still has no effect on the practical use and cutting that anyone would notice.
Of course rust can have an effect. That's not what OP is talking about.You're right, he did say that. I was commenting just on corrosion, not supporting the OP's statement. I see this topic discussed periodically on Bladeforums and on numerous places around the web. Except for the BESS guy, I don't see much in the way of actual science.
I live in the rainforest about a mile and a half upstream from the ocean. Things here corrode fast, which is why I mostly use stainless steel. So, for example, I can't leave M4 steel in a leather sheath for months because it will pit, even if lightly coated with oil when I put it away.
I took a 15X loupe to the edge of my 1095 chef's knife, which has no rust on the blade. But the edge does have rust and heavy patina in many places. Hard to believe that rust has no effect.
Lost me at “after 24hrs of the knife sitting idle it is half as sharp”.
Negative
I did some reading over on the BESS forums, where there seems to be a lot of support for the notion that knife edges do lose some sharpness after sitting overnight.
Neither one of those things seems to be what the op is talking about. Both of what you mention I'm sure is true. He's proposing the steel relaxes and loses half its sharpness over night which simply isn't true.I did some reading over on the BESS forums, where there seems to be a lot of support for the notion that knife edges do lose some sharpness after sitting overnight. There are two proposed causes:
1) After sharpening or grinding, even stainless steels get a fresh oxidation coating. With stainless steels, the coating is about 20-50nm and it then stops. Put this oxidation coating over an edge sharpened to 0.5 microns, and you get a small, but noticeable dulling effect.
https://link.springer.com/article/10.1007/BF01045379
50nm is 0.05 microns, so the effect would be very small.
2) If a burr is left on the edge and straightened by stropping, the burr, which was forced to stand upright from a leaning position, will fall back somewhat toward its original folded position after sitting overnight, causing a loss of sharpness.
http://www.edgeonup.com/KN100_Operating_Manual.pdf (see pages 39-42)
This seems to be edgy stuff, and I'm not sure how to take it; but people with BESS testers say they can reliably produced these effects.
Some discussion:
http://www.bessex.com/forum/showthread.php?tid=229
http://bessex.com/forum/showthread.php?tid=356&highlight=corrosion
But we do know what a sharp knife for use is and we do know that the stuff in the op isn't true and doesn't matter a lick for the end knife user.The people over at the BESS forums play with levels of sharpness many people won’t get.
A guy with a pull through sharpener worrying about this loss of sharpness is like a guy putting a spoiler on his corolla to increase downforce for cornering.
EDIT: your point is well taken. There are a lot of people here making fun of the gun forum guys for believing something they know nothing about. But the people here likely don’t know anything about it either.
If one has Cold Steel Secure Ex sheaths. Otherwise . . . nah dude, nah.Apparently, knives will lose sharpness over time, even when not used at all, and not exposed to rust or corrosion.
