Buck Vantage Pro small in S30V. Opened the box, took the knife out, flipped it open few times, put it back in box. Been sitting on a shelf since. Really poor flipping action and an uncomfortable handle make it a pain to open. Probably should've handled it at the store before buying...
It wasn't too expensive so I didn't bother sending it back. Right now the plan is to sell it or (more likely) gift it to someone with smaller hands.Was there no chance to send it back? It's a pity to see knives gather dust on shelves.
I oiled it with nano oil on the pivot ant detent ball and hole on the knife and played with it for 2 days. It's action was smoother but getting out of the gate didn't wasn't any better. I spoke to a knife guy and he said that they need bend the lockbar a little because because it is pushing too hard against the detent hole. He said it is a very simple fix but I don't want to be the one to do it. Hopefully the will fix it or exchange the knife, if not do you want to buy a knife ? LOLHave you tried to open and close the knife many times? it made the detent weaker by about 30%. The difference is really noticeable. First my finger really started to hurt, because I had to push the flipper so hard, when I got the knife out of the box.
Hey Scott!
If you want an amazing edge on that bad boy, hit Josh at REK up. Fantastic work from a really good guy!!
He'll turn it into a light saber!
Good luck!
Joe
how is it that you can at the same time say "not all 440c knives are bad, you can't say that because some of them are very good." Therefore the poor quality of some 440c knives does not speak for all.
But at the same time say "I have tried a few knives in s30v and CPM154 and they were poor quality, and thus they are all poor quality" therefore the quality of some CPM steel knives speaks for them all, including extrapolation to all powder steels?
Just how much time and money is someone supposed to invest to finally find a good CPM steel?
All the CPM steel knives that I tried were well over $500 customs (Gerber Mark II 70th Anniversary excepted, that was "only" about $300), one was an $1800 RJ Martin Vanguard series Raven (or Blackbird, whichever of the two is the bigger one): How you can call these "low quality" is beyond me...
In total we are talking over $3000 in knives that had to be sold, and were so bad they were not functional as knives.
At least in 440, the bad ones are the minority... And not one bad apple in the half dozen I have seen made of Aus-6/8s...
I have a 75 year old stainless French Sabatier Jeune boy scout knife, a vicious looking 7" fighter-like thing that used to be issued to ten year old Boy Scouts, this in a primitive no-name stainless steel of the 1940s... Cutting cardboard or chopping wood at one quarter the edge thickness and 2/3 the edge angle (10 degrees per side on 0.010" vs 17 dps and 0.040") and yet despite the thinness it made S30V's weak folding prone edge look like an utter embarrassment... Just how much time and money is someone supposed to invest to finally find a good CPM steel?
I found a cheap GSO-10 in CPM-3V, so I will give CPMs steels yet another chance in a few months... Let's just say I am not holding my breath...
From what I have seen so far from $3000 of that stuff, CPMs are not even useable as knife steels anywhere below 20 per side... I you don't rub the edge with your nail to check for micro-rolling, or go below 20 DPS, maybe you won't know the difference...: Perhaps the apex still cuts even rolled over like a drunken sailor, but when I see huge chunks of my nails shaved off on one side after one chop in Maple or one slice in cardboard, I know that $1800 apex is a basket case, no matter how well it still cuts or how abrasion resistant it theoretically is...
Gaston
Since chopping seems to be the main element of knife performance to you, perhaps you should be looking into the materials and construction used in competition choppers. They are the formula one cars of chopping blades.
Just a heads up, they often use the sorts of yucky powder steel you find unusable in a knife blade and not 440 stainless.
I like them to both slice and chop, which is why 15 per side is the maximum angle for me.
You get to 20 per side, and you are trying to cut with a 40 degree wedge: Good enough for choppers, but exponentially worse for slicing... Any steel will probably hold up well a 40 degree wedge...
What I observed is that very few blades will hold up the micro-apex straight at <15 per side angles (so far, steels I saw that did this chopping were D-2, 440B/C, and Aus-6/8). Thin angles also relieve the deceleration on the hand when chopping, which could be more important gloveless in the field than in competitions with gloves...
Lots of competition choppers apparently use Carbon steels, so they clearly don't care much about maximum edge-holding, even in circumstances when sharpening ease is not a factor...
Gaston
Gaston
