- Jun 22, 2003
alright!! last update... cause now its perfect. perfect i tells you....
i beveled out the flat side, overtaking the cutting edge's bevel, and i put a more acute bevel on the originally beveled side - cutting that sides cutting bevel in half. so the end result is that the material right behind the cutting edge has been reduced by 50% or more, and its been rounded out so that its a smoother transition from edge to spine.
this was after much frustration having tried to cut an apple - and the thing just split to the side. just plain old to much metal right behind the edge (wich is to be expected, as i cut the knife off half way up its grind and didnt do anything about it at the begining)
for those who like micrometer readings
the first measurement is from the center of the recurve, 1" forward from the plunge line. the second measurement is at the hump of the cutting edge, 3" from the plunge line. the last measurement is along the spine at the tip.
center of recurve____hump on edge____tip
1/16" -.023___________.029________.029
1/8" - .036___________.037________.038
1/4" - .049___________.051________.055
3/8" - .059___________.058________.064
1/2" - .067___________.067________.072
5/8" - .075___________.073________.077
3/4" - .079___________.079________.079
7/8" - .085___________.083________.081
1" --- .091___________.088________.0825
spine- .094___________.0915
so.,.. while the recuved area is slightly more acute at the cutting edge - i think i did an okay job at keeping the bevels reletively even - for having done it on a 1x30" belt sander from craftsman. i am very, very happy with this knife now.
for random reference - this is the measurements for the edge of the new smith and wesson bowie wich is deeply hollow ground. it is an incredibly thin edge knife for the size (steel heart sized blade)-
1/16" - .030
1/8" - .031
1/4" - .035
3/8" - .043
1/2" - .060
5/8" - .089
3/4" - .110
7/8" - .139
1" - .179
spine - .220
also for reference, here is the decimal numbers for the various inch fractions
1/32 - 0.03125
3/64 - 0.0469
1/16 - 0.0625
5/64 - 0.0781
3/32 - 0.0938
7/64 - 0.1094
1/8 - 0.125
1/16" - .030
1/8" - .031
1/4" - .035
3/8" - .043
1/2" - .060
5/8" - .089
3/4" - .110
7/8" - .139
1" - .179
spine - .220
1/32 - 0.03125
3/64 - 0.0469
1/16 - 0.0625
5/64 - 0.0781
3/32 - 0.0938
7/64 - 0.1094
1/8 - 0.125
