Sorry I've taken so long to respond. The wife and I were getting ready for the Spirit of steel show. It was a great time! Please understand folks, that AG has an ax to grind with me. And he isn't about to tell you the real deal when contacted. This has "NOTHING" to do with Kressler what so ever. As to what would the Loveless shop say if they knew what was being said? There wasn't anything said here inflammatory to anyone. As to what really has been said, They are very aware of it. Now to what I wanted people to look at. This isn't a Kressler Problem. It a problem we all-(Knife Makers) have. It is something we have all done at one time or another, and in all probability will do again. It is a technical thing that is so subtle that I was wondering if anyone would catch it. Any time you introduce a notch into steel, you produce a stress riser. Even if all stress is removed, with heat treat, the notch remains. Take a tree branch, and cut and bend it double. Now cut a notch into the same branch. Bend again. What happens? Now cut a notch into the other side in the same location. Would it be weaker. You bet. I see this on only the chute pictured. Notice the Loveless Chute. You have the main grind, a heavy spine, and a top, or clip grind. When grinding this area, what you are trying for is not crossing the center grind. When you do, the area directly in front of the spine is thinned significantly. The same thing happens when you grind a double edge and slip crossing the center line. The blade will be thinner at this point. This is one of the reasons a double grind is so difficult. One bad slip, and throw it away. On the Kressler, the top clip extends quite a bit below the bottom of the spine, or top of the bottom grind. If you were to look at the clip from the top of the blade, with the edge facing away from you, you would see a stair stepped effect. Much like looking at a bottle neck rifle bullet. The first third of a blade tends to get the most abuse. This is exactly where you don't want such a step down. As I said. This isn't a Kressler problem. We all have done it. I have taken a look at several other Chute Style Knives by Kressler on the net for sale, and much to Kresslers credit, this has been corrected.
