My two day research has limited me to Himalayan Imports and Tora. Tora is more traditional while HI seems to be more evolved. I'll probably end up with some of each.
Personally after a mix of in hand use and online reviews if you were to be using a khukuri for bushcraft and camping I would recommend the Tora over the HI.
They are much better balanced blades with a lighter weight, (that doesn't make it any less efficient).
Just an FYI
I have a Khukuri Imports Operation Enduring Freedom model. It doesn't look that much like the photos.
It's a BAS blem., and I have been posting there. That is where I found the blem.
I'm looking at a 15" Ang Khola, and a Sirupati for future acquisitions.
I heartily +1 the GK khuks. Pradip does good work.Two out the three Tora kukris I own had major heat treatment and blade geometry issues. The were beautiful to look at but wouldn't work worth a damn.
I have owned 50 plus kukris from vintage to modern and from all manufacturers. HI offers the best quality traditionally made Kukri on the market today. Plus Yangdu will fix whatever problems you might encounter just be reasonable and give her time as she is a one woman show. She is the only U.S. Distributer.
The only other Kukri manufacturer I'd recommend is GK knives here on the forum. They are very small and low volume plus most of their blades are villager finished but excellent build quality.
A lightweight khuk with the right geometry will chop (not split, mind) on par with a heavier blade if you have the skillset to run it-they're also easier to hump, especially belt carry...
I've used my bonecutter to chop up a LOT of 2-5" beech limbs (had to run the woodstove well into May, and it didn't warrant real logs) and as a denogginizer slaughtering lambs for a friend of mine. Zero chipping, including shearing through beech knots and sheep vertebrae. It's a 17.5"...kinda wish it was a 16", it would get more use.Also, those GK khuks look nice. The reviews so far have been excellent. The Bonecutter seems to be their bread and butter and it seems a solid field design. I'm curious to see if they experience the chipping which at times plagued the old ones.
