Hi Guys...
You guys pretty much got the idea of it....
A couple of hints though....
You don't need to use expensive molding foam. Blue Sleeping pad foam is good enough.Use spray adhesive to laminate it, then weight it down overnight.
I disagree with 1" of foam though... I use 2-3 inches of foam on both sides. Now on the otherhand,,if you are making real flat knives like Bladewiz,, then 1" of foam is fine...
However the more foam you use the more pressure you will need to use as well. You will get better detail from using thick foam than you will using thin foam, it will sink into the ridges better this way.
If i use an oven to heat concealex,, just watch it,, when it's ready it will more times than not lift slightly.. Push it with your finger to test if it's soft enough.
Why aren't you guys using some type of a clamping system....
The trick to doing kydex work is steady downward pressure. If you rock back and forth on it,, there is a likelyhood that you will move the blade around inside giving you an inaccurate fit.
Use the same setup you are using,, but use clamps,,load some bricks onto it or even back the car ontop of it,, Anything but rock back and forth.
If you are rocking on it,,to get good detail,,you aren't using enough foam....
Hope this helps somewhat...
Eric....
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
Custom made, High Quality
Concealex Sheaths and Tool Holsters
Canada's Only Custom Concealex Shop!
