I care that first you're going to evaluate the steel based on composition and cutting performance, and then point to tests designed to stress a knife to determine toughness to validate your opinions. It's just hypocritical.
If I was going group camping I would probably bring an ax and a saw. If I'm going by myself, it will probably be staying home. I don't plan on taking out a tree every time I go outside.![]()
Knives are for cutting - one thing.
Thanks, Vassili.
Perhaps you should add something like "In my usage" or "as far as I am concerned" to your statements. Throughout many cultures knives are used for chopping, and are even designed for such activities. It is clear that you have your own personal beliefs, but please state them as such. To disprove your statement one must only look at a Nepalese Kukri- a knife designed for chopping.
I am not sure where you get it from. Knives are for cutting - one thing. If you are looking for toughness - Noss4 test are best place for this - is another things. Sure. Whatever. I do not see any problem here or how they related - both is true at least from my point of view. Until you are looking for something else. I am not sure why you switch from original topic to my humble person. Because the original question was why are these knives laminated and what does that do to the knife. Increase toughness and corrosion resistance. Then you came along and said VG-10 is not good steel, and it's comparable to CS's AUS-8A.
Well, when I was going to biking or kayaking trip for week or more I took good small axe with me and do not care too much about knife. Personal choice. Knife was not on most important things - just for "selfdefense", I've got a great pair of running shoes and a Surefire which are my primary means of SD. which is usual concern for teenagers everywhere.And in the forest there are quite a bit of fallen trees in different condition so you do not need to cut tree to get good log to make all night long fire. Hence my argument that if I'm backpacking alone I wouldn't care to much about an ax. All dependent on where I am going to be and for how long.
I am not sure where this idea to get tree every time going out came from - is it normal fear reaction on someone carrying axe? I'm terrified. Honestly.
Thanks, Vassili.
Sorry, but the Noss4 tests are not truly controlled tests by any stretch of the imagination. They are fun for kids to watch, but have little value beyond the level of sophomoric humor. You complain about knives being used for chopping, yet you seem to like someone who definitely takes knives well beyond their intended design parameters. Concrete blocks? Hammer to the spines in a way that does not take into account resonance frequencies? How is much of anything the guy does reflect a scientific knowledge of metallurgy or understanding of design parameters? You state that knives are meant solely for cutting, but you cite a guy hacking into concrete blocks as gospel? If anyone is "Hollywood", it's Noss4. I feel you are seriously confused at the very least. As far as my having a vested interest in any of the knives he's tested, simply not the case.Axes are not knives - this is too much to say.
And Noss4 tests perfectly scientific, if you know what does it mean and not using this "unscientific" complain just because you do not like outcome for certain brands, based on some Hollywood idea what science is.
Just curious, if knives are meant solely for cutting, why are there knives over 6" (just a ballpark figure) in blade length? What possible need could there be for draw/push cuts done with something like a 10" blade? Why would knife manufacturers market a 10+ inch blade as a "chopper"? How is a machete not a chopper? Are you using draw/push cuts when using one? If so, how tired are you after removing a few half inch limbs? Wouldn't a saw/ax be a better tool? How does batoning fit into this purist slicing only ideal? Why are Nessmuk style knives considered such good all around knives for chores that include by intent, chopping?
Fact that there are few specaily designd for wood choping knives emphasise fact that in general knives are for cutting. Even machetes is mostly for cutting through jungle not for copping wood. And khukry is made almost in a form of axe, being actually som hybrid between knife and axe, because axees are for chopping wood and knives for cutting, this is why if you need chopping from knife - you make it as an axe. But average axe outchop any khukry.
Thanks, Vassili.
..I've been checking out the Fallkniven line of knives and see that its convexed(?) and laminated.. ..is there special care needed in sharpening a laminated steel knife so as to keep the steel sandwich in the correct proportion?
Why 5 why not 100? Is it magical number making it scientific.
Not at all. He has same procedure for every knife and with certain probability it show what to expect from this or that manufacturer.
For example if he get knife made out of wood and it fail. I guess nobody will ask to test 5 of this knives before make conclusion. Science deals with all kind of information and sometimes with fenomens which happened very rare. So it is not required to have 5 observation to be scientific. What are you talking about is how representative this tests are. But we deal with this all the time - and results from one knife also valuable, until he use same procedure for all of them.
People who attack Noss4 does not realise that only valid way to prove that it is not representative is to increase number of observation - do more tests. But so far nobody like to do real work, just talk and get angry.
Thanks, Vassili.
P.S. You may talk a lot about inaccurate tests - but you do not even bother to chack my tests - I did not test VG10 yet.
Do your own tests and then I will listen to you on how inaccurate my tests are.
Unless he states edge angles and types, like you did, those charts don't have pretty much any meaningful interpretation from the comparison standpoint.For reference, I tested my Spyderco D'Allara (VG-10) against a master hunter in CPM154. The D'Allara had a 30 edge angle finished on the flats of my white sharpmaker rods, the hunter was convexed.
Using different angles I can make 440C outlast ZDP-189 or CPM-10V easily. Which wouldn't be a true picture.
