The nice thing with using string and rope is that the strands are smaller in diameter than the edge bevel, so the thickness is the same when the material parts.
Agree about the string, but that's just a control/measurement cut. Rope, which consists of multiple, intertwined(?) strands is still not the same as single strand. When pushing through it thickness matters.
Honestly, I find it doesn't matter if you put in enough time.
Unless the final edges are of the same thickness, otherwise it sure matters.
Let's do some very simple math/physics ok? I'll use SI system for simplicity.
P = F/A. Where P is pressure, F is force and A is the surface area. For the sake of example, let's consider that edge tip, or contact surface, is rectangle( it's a wedge after all), constantly 1micron long, width will be variable, depending on the abrasive used.
For the case when 100g force was needed to cut the string, with the blade sharpened on 1200 grit sharpened, edge width would be ~7mic.
Using the formula we have: 0.1kg/0.000007m ~= 14285.75p.
Now, we can safely assume that 14285.75p is the pressure that is required to break that strand.
Using that pressure, we can find the force necessary to break the same strand at 5mic for example, F = 14285.75p x 0.000005m ~= 0.0715kg, or ~71g.
If you look at his sharpening test tables, on 100th or even 200th cut the differences rarely exceed 30g, more often it's considerably less.
So... To me, that looks pretty imprecise, or inconsistent to judge metal wear resistance by those results.
Now, depending on what type of steel you're stropping with CrO and how you do it you can easily get quite distorted picture. ZDP-189 won't wear at the same rate as S30V or AUS-8.
The simple fact that in his own table, the force required to cut the string 1st time, varies by as much as 100%(10g and 20g) does tell me that sharpening results are quite inconsistent.
I personally think that is the result of going to strop from 1200 grit. Yes, it does improve sharpness, I am not arguing neither the usefulness of stropping, nor the apparent improvements in sharpness.
I do argue however, difference in initial sharpness will provide incorrect picture for steel comparison in terms of wear resistance.
I don't believe that every knife can be brought to hair whittling sharpness(which seems to be Vassili's sharpness criteria) using 50 strokes per side on CrO loaded leather right after ex fine DMT. Especially, when those DMTs are those narrow diafolds and it's not that easy to keep consistent angle on handheld sharpeners.
I don't even know what's the starting point, after 50 strokes on the CrO strop or when it is hair whittling?
The coarsest edge I have split a hair with so far was sharpened on coarse crystolon (100 grit, 141 micron size)
No, I am not there yet, haven't even tried that. Although, considering that the human hair is 50mic thick it's a pretty hard feat
May be the hair got stuck on exceptionally large carbide
