Based on my experience and all the metallurgical research I read throught the term "supersteel" is not being used in material research science
this term was simply created for marketing purposes relatively recently.
At first if you dont know how the blade was heat treated the chemical composition of the the blade material respectively steel type has
such a wide sprectrum of how it could possibly behave that it has no point to focus on a particular steel exclusively.
In general once there is enough carbon in the steel to allow it to harden there is a very basic principle:
The more carbon the higher hardness/strength can material achieve after heat treatment
while at the same time its ductility is decreased.
All these so called supersteels are quite high in carbon and many other alloying elements making them very wear resistant
relatively strong[depends] however their toughness is compromised. Carbon content of these is anywhere between
1% and 3% or even over which is too high [despite the PM production] to allow these materials to be resistant
to hard impacts. So it is always a compromise and for each steel there is more and less optimal application.
Certainly lower toughness can be compensated by design with thicker geometry and higher edge angle to prevent chipping
but it wont cut so well any more. Again the compromises ! :jerkit:
So if u have 2 steels of similar composition the one with less alloying and less carbon will be tougher.
the one with more alloying and more carbon will be more wear resistant. There is no steel that is ultimately
superior in everything or vice versa..
