The titanium steel sides are more impervious to rust and corrosion than plain stainless steel (unless its the kind of stainless steel that has a very high percentage of titanium in it
). The titanium sides give the Charge a more rounded feeling on
both sides of each handle whereas the old Wave was rounded only on one side -- the outside if yo had the pliers open - the inside if you had the pliers folded up -- which helped with the pliers but not the other tools. Sides rounded along each edge is a small but appreciated improvement, making the tool more comfortable during any use. The sides are just a little bit darker than the stainless steel, not the dark gunmetal/ black-chrome color you see in the Leatherman website pics.
In the holster with the bit holder, the whole thing weighs 2.5 ounces more than the Wave in its holster. Of course, if you added the Wave's extra bits and bit adapter, the Charge would be lighter by a hair.
The items all have nice little crooks you can easily catch with your fingernail to open them. Much nicer than the small nail nicks in the old Wave. Clumping is indeed gone and the tools open out very smoothly. The clumping was used on the old Wave so you could access the "inbetween tools (pull out the one next to it and they both came out, then put back the one you weren't really after). The Charge tools come out one at a time so each item has its own little crook to grab it by.
Outer blades do open more smoothly than the old Wave and on the old Wave they were pretty smooth.
Pliers gives a bit more resitstance for the first few degrees of opening, but they work slick as silk once opened.
I found that the mini-bit screwdriver fits very snugly into its seat. Won't fall out by gravity alone -- in fact, it takes a pretty good tug to yank the bit out to reverse to the mini-philips head. I suspect that if it comes out via gravity alone, that's a defect in that unit.
The bit holder is not the dipped-in-batter type that came with the Super Tool, etc. It's a strong plastic plate about 1 1/4" by 4" by 1/4" and the bits fit into slots molded into this plate.
The holster comes only in black. The holster has internal elastic (Lycra style) panel that holds the bit-holder flat against the inside back of the holster. The sides of the holster are narrow double layers of elastic with no leather over them. Yes, the sides of the holster are just elastic (Lycra) panels! This holds the Charge very snuggly in the holster and it takes a yank to pull it out. I don't like the elastic sides, myself, but they will let you insert a small maglite or such between the double layers. I suppose the elastic sides also help hold the Charge in place when you have it inserted in the pliers-open position. The bottom of the holster has a hole cut-out so you can insert the Charge pliers head down in the holster while the Charge is in the pliers-open position. Although I've seen photos of the holster closed with the Charge in the pliers-open position, mine won't come even close to closing that way -- only closes when the Charge is all folded up and even then you have to pull down hard on the flap to get it to reach the snap. I suppose some of that will loosen up with breaking in. The holster is a thick high quality leather but I liked the brown deluxe old Wave holster better. Since the Charge is thicker than the Wave, the old Wave holster is a little too narrow to fit the Charge into it. You can force it in but it's hard to remove once you do. The whole holstered Charge shebang sits on your belt about about 1/4" or more thicker than the old Wave.
The scissors is much smaller and thinner than the old Wave, which had very nice scissors for small scissor -- as good as those on Squirt. I like the old Wave scissors much better than the Charge Ti scissors. The Wave scissors, they were beefy enough to be used as scissors on more than just fishing line. The Charge scissors might be as strong -- time will tell -- but they are significantly smaller and thinner.
All the internal tools lock and unlock the same way on the Charge. Opened, they catch on a small tab of a springloaded bar that's onthe back of the handle -- you press the other end of the bar with your thumb and the tabside comes up, thereby releasing any tools on that side of the Charge. I thought there might be a problem with accidentally depressing the thumb bar and unlocking a tool while grasping the tool tightly in use. But the thumb bar must be depressed below the surface of the handle to unlock any item and I haven't had a problem with unintentional unlocking.
The external blades lock and unlock via the same mechanism as the old Wave -- was a very nice and reliable mechanism.
The bits being narrow in one dimension certainly won't be an issue for standard blade screws. But it might for philips, square drive, and hex head screws. For those, the narrow bits mean the bits won't grab on all the surfaces -- for example, a philips bit will only get a full bite on two of the wings instead of four. I haven't used it enough yet to know if that's going to matter in practice or not.
Overall, a decided improvement over the old Wave in the ways it was meant to be an improvement. A little bigger and heavier -- which might be good or bad or neither here nor there, depending on the individual user. And "fixes" the major peeves folks had with the old Wave.
Wish list for the next generation Charge Ti?
- A holster like the old Wave deluxe holster but with an internal elastic panel to hold the bit-holder plate.
- Scissors like the ones on the old Wave.
- And maybe, full width bits, too.
sh
