- Dec 13, 2010
Shoulders up as high as you can manage, and pulled back.
Shoulders in a shrug?
Bench press is one big difference. You'll lift with the bar positioned higher up (just under your neck, and well above the usual area). With your shoulders pulled up and back, and back flat, you'll end up building muscle higher, so it will layer up and over your collarbone, and, combined with the traps and delts, will protect your shoulders.
Haven't done it yet, as my gym days are on Friday. I'm wondering though, why not do incline presses to build muscle higher up rather than shrugging and having it over the collar bone? Weight right above the collarbone shifts stress from the pectoralis minor and more on the anterior deltoids at a potentially awkward angle.
The idea is to build muscle around the joint naturally. Remember, if you follow the program exactly, you'll be doing less weight at first, because you're moving the weight just with your pecs and arms, so it will be harder. It doesn't actually put bad stress on your anterior delts because they're supported by the bench, if you're doing bench. More, it shouldn't be an awkward angle because if you hold your hands out in front of you perpendicular to your body, that's actually the natural place for them to be.
Not only that, however, but if you try incline presses normally, you'll probably notice that you are actually pushing your shoulders forward. That's why many weight lifters end up with a hunched posture. That's not actually beneficial for one's spinal or muscular health, and often results in joint injury. You probably know how common shoulder injuries are. None of my father-in-law's athletes have had a shoulder injury since they started with him, and that includes professional football and baseball players. More, you don't actually layer muscle up higher above your collarbone by doing incline presses. If you don't do that, the muscles end up being more discrete. The idea is that you build a cushion of muscle completely surrounding that joint, which serves to hold it in place.
Sorry but I feel the need to correct you on this......
- There is no such thing as just using your pecs and arms when it comes to bench pressing, a lot of it involves your shoulders, triceps, and even your back.
- If you want to put less stress on the shoulders on the bench press, use the powerlifting form (refer to video posted).
- Weight lifters do NOT have a hunched posture, not sure what kind of weight lifter you're looking at. If someone does have a hunched posture caused by weight lifting, it's because they only workout their pecs and neglect to workout their back.
Here's a great video showing proper benchpress form:
http://www.youtube.com/watch?v=_QnwAoesJvQ
Since you haven't tried the program, I'll just point out you have very little standard of comparison. And it's also worth pointing out that your triceps are part of your arms. Shoulders also are kinda attached too, as long as we're being picky. As for the back, well, many people arch their back up off the bench when they're benching. I realize you may say that's bad technique, but just the same, when we're niggling about technique, then there's a lot more nuance to it. I wasn't really planning on explaining the entire program form over the internet, because that's very difficult to do, and those that are interested should consider checking out the book or working with the author.
But, as long as you're going to "correct" me, I'll go into a little more detail. Yes, you use your shoulders and back in bench press. However, the position that you have them in dictates which muscles are primary in the lift, and allows you to better focus your attention on developing certain muscles. If that's not something you can agree with, we're going to have very little agreement. Many people will use their shoulders to do a lot of the lifting, as well as arching their backs. As a consequence, they're going to develop very differently, because they're using those shoulder muscles to push weight forward. That's naturally going to pull their shoulders forward as well, resulting in the hunched posture that I was talking about. YOU may not think of the posture as hunched. But by the standards of the program I'm talking about, many (probably even most) people who lift weights have their shoulders forward, and very pronounced collarbones, instead of a smooth slab of muscle. And frankly, if you're doing it right, your shoulders barely move, and they're certainly not going to be tired at the end of a set. Same deal with lifting so the bar comes to your nipples, which are really the bottom of your pecs. That results in developing your pecs lower (big surprise). Sure, you can do other exercises to compensate for that issue. But while you're doing 3 different exercises, I can do one and get the same results. If you're not a professional, and you're just trying to stay fit (which I think was sort of the point of this thread), efficiency counts.
As far as your video goes, while it's not my program, and I am not certified to teach it, there are several points of inconsistency that I notice. For one, his back isn't flat against the bench. So he's arching up, which serves to pull the shoulders down towards the ground, and thereby reduce the mechanical advantage from the lift. For two, his shoulders aren't actually pulled together and back, which means he isn't going to build the same way. Third, he brings the bar to touch the lower part of his pec. That's going to develop your pecs lower, which also misses the point entirely. There are more points, but I don't really want to debate lifting technique here. That wasn't the point of my bringing it up.
While there's plenty of truth to what you're saying, it strikes me that you've missed most of the point of the program. You may be happy with what you're doing, and that's fine. This thread, from what I understood, is about motivating people to stay fit. I brought up this program because it's very different from what conventional weight lifting coaches teach, and I felt that Qeth might find it interesting. If you don't, that's fine. I personally avoid conventional lifting programs and techniques, especially like the video you posted, because I feel that it's a less efficient method and doesn't develop the pectoral muscles in such a way that I protect my shoulders. If it did, shoulder injuries would be much less common. But again, that's just what works for me. I do not care to debate which style is the best. I was merely offering something different that very few people have seen, that I found to be revolutionary and interesting. If you don't like it, fine. But perhaps you can avoid offering "corrections" on something you've never tried.
As I said I don't know anything about your program, I don't even know where you posted it up so I'm not directing this towards you. My corrections were initially directed towards that one post you made in which the info was in fact not correct. If you still don't agree with me, then we can agree to disagree.
