- Jan 12, 2021
I don't know, they have been pretty consistent with itI feel the same way. It just works. I hope the wait isn't too long for the next run but I'm thinking it might be a while.
Not only is it ok, it's food safe too!It’s ok to use mineral oil isn’t it? I’ve been using it on my joints via Qtip and then rub the excess from the spring into the wood or bone.
Mineral oil is hard to beat.Not only is it ok, it's food safe too!
I apply it more liberally than you've described as I've found that a good soaking with mineral oil helps wick any residual polishing compound, or other forms of mung, out of the joints and seems to help the bearing surfaces wear together the way I like during break in.
I used to use Mobil 1 synthetic (it's food safe too, BTW) and still do on my firearms, but on the occasion that I need to cut a good steak, I prefer for it not to taste like motor oil - if I get judged for that, I'm ok with it.![]()
I use mineral oil on the joints and blades, but I don't rub it into into the covers (unless they're wood, in which case I might, particularly of it's ebony and looking 'tired'). This is because I have a horror of verdigris, and I'm told oil can encourage the reaction between copper (present in brass liners, brass pins, and nickel silver bolsters) and stag (or bone) which results in verdigris.It’s ok to use mineral oil isn’t it? I’ve been using it on my joints via Qtip and then rub the excess from the spring into the wood or bone.
Ballistol is used if I’ve been cleaning guns recently. (It’s also food safe.)
I think that's just a generic warning, to cover the manufacturer/seller. Mineral oil is known to hasten your regular toilet visit if you drink it - it is sometimes recommended as a laxative. The quantity you might ingest through knife maintenance is negligible.Are you sure about that? The label says “Eco-Friendly, Skin Safe, No Carginogens”, but it also says “Harmful or fatal if swallowed.”
Me too.I use mineral oil. Any mineral oil that comes from a pharmacy is food safe, but just because it’s mineral oil doesn’t always mean it’s food safe. Or so I’ve been told.
Correct, not all are food safe.I use mineral oil. Any mineral oil that comes from a pharmacy is food safe, but just because it’s mineral oil doesn’t always mean it’s food safe. Or so I’ve been told.
I wasn't suggesting you neck it neat from the bottle, just that ingesting the occasional trace of it will not harm you.Yeah, but Ballistol isn’t just mineral oil. Based on the smell alone I wouldn’t chose to ingest it or use it on knives I planned on using for food prep, but hey, to each their own…
Mineral oil doesn’t encourage verdigris. It may seem like it to some people. However, it can spread verdigris that is already there hiding around the pins and liners. Basically it can cause it to leach out and become more noticeable if it already there. Verdigris is a chemical reaction of the copper that is in brass with oxygen and it is increased when there is exposure to salt.I use mineral oil on the joints and blades, but I don't rub it into into the covers (unless they're wood, in which case I might, particularly of it's ebony and looking 'tired'). This is because I have a horror of verdigris, and I'm told oil can encourage the reaction between copper (present in brass liners, brass pins, and nickel silver bolsters) and stag (or bone) which results in verdigris.
There's a lot of conflicting advice out there about this. I've read that oil (even the oils naturally occurring in a leather slip) will promote verdigris, and I've read the best cure/prevention for verdigris is soaking in a bath of oil for 24 hours! Who to believe? It developed on two of my beloved stag GECs before I learned what it was, and I hate it so much that I'm taking no chances. All seem to agree that RenWax is a good idea (it would certainly form a barrier of sorts to the salts on our hands reaching the handle), so I regularly slather with that.Mineral oil doesn’t encourage verdigris. It may seem like it to some people. However, it can spread verdigris rust is already there hiding around the pins and liners. Basically it can spread it if it already there. Verdigris is a chemical reaction of the copper that is n brass with oxygen and it is increased when there is exposure to salt.
That is what I was taught by one of my friends and mentors when I started collecting- mineral oil and a little bit of RenWax.There's a lot of conflicting advice out there about this. I've read that oil (even the oils naturally occurring in a leather slip) will promote verdigris, and I've read the best cure/prevention for verdigris is soaking in a bath of oil for 24 hours! Who to believe? It developed on two of my beloved stag GECs before I learned what it was, and I hate it so much that I'm taking no chances. All seem to agree that RenWax is a good idea (it would certainly form a barrier of sorts to the salts on our hands reaching the handle), so I regularly slather with that.
